Just wanted to add a tip that worked for me because some of the paths caused my system to execute and install seemingly ok, but then at the login screen I couldn't enter a username.
* Assume all scripts have been run and you've gotten as far as the VIDA login screen
* shut down vida
* Put the small patch file in some directory away from c:\vida, I used c:\temp
If you execute the patch exe, it wants to put 2 folders (jboss\ and patch\ ) into the destination (vida) folder but that doesn't always work.
Run the patch .exe, but direct it to extract to the temp directory that's below where you've put patch.exe.
So for me it ended up as
c:\temp\patch.exe
c:\temp\patchfolder\jboss (this is a folder)
c:\temp\patchfolder\patch (this is a folder)
-> I created patchfolder to keep it separate from the patch.exe
* open the file c:\temp\patchfolder\patch\license and change the subscriptionExpireDate attribute to something past today (I set mine to 2025), and save the file
* now, MOVE the patch folder and its contents to c:\vida.
Run patch.exe again.
I noticed that this still gives a tskill error, but things otherwise work for me, so I'm not pushing it. I hope this helps someone after a day of hitting my head against a wall.
VIDA 2014D_Repack install on Windows 10, any version.
digraph909
- Year and Model: 2017 XC60 AWD
- RickHaleParker
- Been thanked: 980 times
tskill is Windows XP. For Vista - Windows 11, tskill is available as taskkill. That why you get the error. You could edit the scripts in the patch by changing tskill to taskkill. Most people don't have a problem with the error. That why it never got changed in the patch script. The patch is a self executing WinRAR file. You can open and edit it with WinRAR.digraph909 wrote: 10 Aug 2022, 05:04 I noticed that this still gives a tskill error, but things otherwise work for me, so I'm not pushing it. I hope this helps someone after a day of hitting my head against a wall.
You might be able to make a copy of taskill as tskill. That should let Windows find the command with both spellings.
Active
Past
Past
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
One thing I do not understand is after the program has been out for this long, why has no one dumped it to pure HTML and uploaded somewhere so we can access the data without the IE requirement.
Reason: edited
Reason: edited
- RickHaleParker
It is a Microsoft SQL database running on JBoss Application Server 7 with a few support programs like IsoView for the vector graphics.dikidera wrote: 27 Aug 2022, 08:35 One thing I do not understand is after the program has been out for this long, why has no one dumped it to pure HTML and uploaded somewhere so we can access the data without the IE requirement.
Open a browser and go to address 127.0.0.1 when Vida monitor is running.
127.0.0.1/Vida/ ( localhost/Vida/ ) is the address for Vida.
Active
Past
Past
gigatech707
- Year and Model: 2005 xc90
Hello, I'm having trouble logging in. it doesn't matter if i use admin, or 1, 2, etc.. I get " unknown error, please contact help desk." Im using IE tab on edge. it does the same on chrome. I've had this successfully running on a previous laptop, not sure what's goin on. Any help would be appreciated.
Thanks.
Edit- Figured it out. had to stop VIDA then reinstall the patch.
Thanks.
- RickHaleParker
If you can convert Vida to html and find a work around for everything else like ActiveX controls .. we will erect a statue of you in the MVS hall of fame.
Active
Past
Past
- Has thanked: 2861 times
- Been thanked: 1332 times
I poked around in there with the same idea in 2008 or 2009. I don't recall the issues I ran into, but I recall abandoning the project (not for copyright reasons, for technical ones).
Espen Beck
- Year and Model: XC70, 2001
Hey Rick,
Great write up and happy to see that there is a patch for Windows 10
However i am having problems with running the scripts 1-3 as my computer throws a message that they ar 16 bit, and it needs 64bit scripts…
Any chance you can help with that?
Espen Beck
V70XC Cross Country 2,5 AWD, 2001
XC90 R-Design 2,5D AWD, 2014
- RickHaleParker
The scripts work on 64bit operating systems. Got to be something in your system or something your doing different.Espen Beck wrote: 01 Sep 2022, 15:11
Active
Past
Past
- 11222 Views
Last post by Stasiuss
- 5067 Views
Last post by big305
- 6034 Views
Last post by RickHaleParker
- 3200 Views
Last post by rusty volvo
- 4548 Views
Last post by wizechatmgr
