DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 71 times
Post by DennisCA »
Started with the base coat, finally. I just did the drop coat after these were taken.
I've prepped a lot for this, high build primer, got blocked down, then I put another layer of epoxy as a sealer over that and I wet sanded it with P600 paper
And today I put down the base coat:
I've just put down a drop coat to heighten the metallic feel. I think I'll hold on until tomorrow for the clear coat.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Very nice !
Make sure that the roof trim is well attached, especially from the roof down to the cowl. I had the wind pull one of mine off that I had replaced when I was going at a rather high speed. It bent right at the roof and flapped along the drivers side window till I could pull over.
Surprisingly it just bent back with no real damage. But now they have a dab of sealant down by the cowl.
1999 V70 GLT
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
BlackBart wrote: 22 Aug 2025, 10:24 NObody needs a V12 Jaguar.
Unless it’s like, a 1962…..
<EDIT>...wait, that ain't right, they didn't have them yet.
But I WANT IT!!!! :lol:
It does have issues, like oil leaks, no AC, no heat, drivers side door sits funny. It does seem to run well, and looks really nice. Very minimal rust (not enough to worry about on a fair weather car, for me).
I'd need to get rid of another car right away, if I bought it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Got caught in the rain and seem to have spring a new leak.
I can't tell if it's from the windshield, or if rain crept in when I got in the car from the uncompressed door seal or similar. It's been through a couple monsoons already including one a couple weeks ago with no issues
imgur.com/a/VCSwqRq
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Has thanked: 1613 times
Been thanked: 4075 times
454cid wrote: 23 Aug 2025, 21:08
Lucas, inventor of the short circuit
454cid
Post by 454cid »
abscate wrote: 24 Aug 2025, 04:55 Lucas, inventor of the short circuit
The ignition did change over the years, but this particular one does indeed have a Lucas ignition. I'm not sure about the other electrical systems.
While starting it sounds like a small WW2 fighter.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
454cid wrote: 23 Aug 2025, 21:08 But I WANT IT!!!! :lol:
The car lust is strong with this one, Obiwan.
(I have it too….)
eliasx
Year and Model: V70 1997
Post by eliasx »
jsrnsis wrote: 07 Jan 2024, 14:01 Is there any workaround for discontinued part 9157320 and $100 part 9157321 for the AWD p80 rear suspensions? They're the bushings and support plates for the top of the nivomat shocks, and I fear that they may be going bad on my XC. I recently laid down the $600+ for new nivomats as I couldn't find a definitive way to side-grade to regular rear shocks and springs and keep the XC ride height.
I've run into the same issue - need a replacement for the old #9157320, or some other way to attach the AWD rear suspensions.
I bought some non-nivomat suspensions, but the top attachment is the same. Maybe it's possible to machine a matching part.
Would be easier if I still had the original to use as a template though.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Post by jsrnsis »
eliasx wrote: 25 Aug 2025, 04:18
I believe there are two pieces, the cups that go on top of the shocks are still available but pricy, the other part is a metal cup covered in rubber if I remember correctly.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
jsrnsis
Post by jsrnsis »
Does anyone in the Hudson Valley or surrounding area need doors off a 97 nautic blue 850 with a tan interior? Or seats, interior trim, sedan rear speakers, gauge cluster with fixed odometer, 130k mile engine, intercooler, <2000 mile radiator? If you need anything, please send a DM before it goes to a scrapyard.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
