Amazingly well documented Odometer Fix
This topic is in the MVS Volvo Repair Database » How to Fix the Odometer on your Volvo 850
tzanis
Year and Model: 1997 850 GLT
Post by tzanis »
Ozark Lee wrote:I replace all of the lamps, working or not, when I repair the gear anymore. The amount of jostling getting the cluster in and out will break the filament on used bulbs about half of the time. I had similar issues when I changed the gear on my first 850.
The main lamps are easy, any auto parts store will have them, but the smaller lamps are tougher to find. I think Robert (member name RSPI) sells the warning lights for considerably less than a dealership.
thanks lee, I ll go check at the parts store and buy the main ones then at least. most of the others small ones work fine still.
dosbricks wrote:tzanis, I'm not sure if your '97 has an option to reset your service reminder light, but my '96 did not, so I pulled that bulb when I replaced my odo. gear. Just a thought.
Yes, I took the service light out too when I took the cluster out, and it was from the first things I was thinking of doing, but thanks for the thought.
