Hello I followed the steps according to the guide but I'm facing errors from the run files 3/Patch 2099 both is giving me tskill.exe is not recognized on CMD followed by Windows cannot find %VIDA_HOME%patch\filldb.cmd
Currently using a brand new Lenovo x1 carbon gen 9 on Windows 10 Pro
VIDA 2014D_Repack install on Windows 10, any version.
- RickHaleParker
- Been thanked: 980 times
tskill.exe is located in Windows\System32\ . Copy it to Windows\SystWOW64\timmyong wrote: 19 Oct 2022, 20:45 Hello I followed the steps according to the guide but I'm facing errors from the run files 3/Patch 2099 both is giving me tskill.exe is not recognized on CMD followed by Windows cannot find %VIDA_HOME%patch\filldb.cmd
Try right clicking on the patch and run it as administrator.
If that does not work. Try disableing Windows Defender. Windows Defender gets a lot of things dead wrong.
Active
Past
Past
i got a new error 15105: The resource loader cache doesn't have loaded MUI entry.RickHaleParker wrote: 19 Oct 2022, 22:20tskill.exe is located in Windows\System32\ . Copy it to Windows\SystWOW64\timmyong wrote: 19 Oct 2022, 20:45 Hello I followed the steps according to the guide but I'm facing errors from the run files 3/Patch 2099 both is giving me tskill.exe is not recognized on CMD followed by Windows cannot find %VIDA_HOME%patch\filldb.cmd
2020 Volvo V90 T6 R Design, B4204T27
Dgrabke
- Year and Model: 2001 v70 2.4T
- Been thanked: 2 times
Got it to install, but running into trouble logging in. at the login screen, using admin......opens WSL Login window, then states "Navigation to page has been cancelled". Not sure what I'm doing wrong.
- RickHaleParker
You got so may problems with that machine I would wipe the hard drive and install a fresh copy of Windows.timmyong wrote: 19 Oct 2022, 22:51 i got a new error 15105: The resource loader cache doesn't have loaded MUI entry.
Active
Past
Past
- RickHaleParker
Windows Subsystem for Linux (WSL) ...Dgrabke wrote: 02 Nov 2022, 08:19 Got it to install, but running into trouble logging in. at the login screen, using admin......opens WSL Login window, then states "Navigation to page has been cancelled". Not sure what I'm doing wrong.
Active
Past
Past
- RickHaleParker
The 2014C German language pack should work with 2014D. I think you need to include and select the language pack at the time you do the install. Add the German language pack folder to the DB folder in the 2014D_Repack.iso . It should show up in the language selection list when you are installing VIDA.RSchally wrote: 04 Nov 2022, 17:14 how can I get the German language package (got db files from 2014C) run with that?
You might pack the German language pack folder into a zip file and attach it to your next message. Some other people may have a use for it.
Active
Past
Past
Thanx for getting and let me thank you again for that great job. Did try a thousand times to install but no success unless I found your repack...
I did install German (copied files to specific folder), made new .iso and it German language shows up when installing VIDA but at the login (in VIDA, where you enter admin or the numbers) was greyed out, couldn't enter anything. And a bit below it names the version installed but no language.
Can I mount your .iso, copy to a folder and install from the folder or does it have to be installed from your mounted .iso?
Would like to upload but it is above 200MB
- 11361 Views
Last post by Stasiuss
- 5143 Views
Last post by big305
- 6113 Views
Last post by RickHaleParker
- 3339 Views
Last post by rusty volvo
- 4642 Views
Last post by wizechatmgr
