Panel removal is covered in this tutorial;
https://www.matthewsvolvosite.com/forums ... lit=+wiper
1997 850 rear wiper wiring break repair
V70 2000 Rear Wiper stopped working...Problem solved!
Jack Rock
- Year and Model: 1998 V70R
Re: Advice: give that ol' rear wiper a look
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Here is what I did a few weeks ago:
http://www.atthetipwebs.com/technologyi ... _hatch.htm
NielsinColumbus
- Year and Model: V70 XC 2000
You are all such an amazing group of people. I just did this repair on my 2000 V70. With the excellent step-by-step instructions and pictures, it was a breeze. Thank you so much!
- Has thanked: 1506 times
- Been thanked: 3822 times
Thanks for bumping this thread. My V70 rear wiper was in 'tailgate open only" mode a couple of years ago, but working fine now. Im sure I have one of these same wires open and will certainly bookmark this for a warm winter day project.
Keyword V70 rear wiper broken wire
turletbowels75
This was extremely helpful. I had the exact same problem, same place and everything. Four cut wires, and since I kind of knew where to look, only took about thirty minutes. I can finally lock my tailgate again without having to climb over the seat to unlock. Thanks a million.
Here's what I found when I did the same digging
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Quite often the copper strands break inside the insulation so give each individual wire a good tug where the wire bends at the tailgate hinge point.
One other issue I have seen is where multiple wires short out at the tailgate hinge point due to insulation break down, left unrepaired such a short circuit can cause wiring fires, I spent two days re-wiring a phase two V70 that had suffered extensive wiring failure (burnt cables) that started from the tailgate hinge point. In this instance the shorted cables had also managed to damage the CEM - If in any doubt give these wires a good inspection as they will fail at some future point - Mike
