Oil in coolant 02 S60 2.4T
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Oil in coolant 02 S60 2.4T
Post by MoVolvos »
I found these helpful since the Topic is Headgasket!
How To Tell If Your Head Gasket Is Blown
How To Fix An Overheating Car
JWHunterinTN
Year and Model: 2002 S60 2.4T
Post by JWHunterinTN »
I am pretty sure the steel seal is still good, # 5 is not getting water intrusion. My thought process is that the gasket is just deteriorating (02 with over 100,000 miles) or the head is slightly warped due to overheating once. I see it as at least two seperate leaks, one fixed with the SS which was a coolant leak into cylinder, the second was oil into coolant and then collant into oil which I think is the same leak.
Any thoughts on the tool that holds the timing gears in place during work??
Jeffrie
JWHunterinTN
Awesome links! After talking to the tech guys at SS that is the process I used, and it worked great. Will find a test kit and do the cumbustion gas test..........thank you.
Jeffrie
MoVolvos
Post by MoVolvos »
Jeffrie
I have not done a head gasket nor timing belt for over 25 years so...
If you need to work on the Head Gasket perhaps this maybe helpful even though it is for the 850.
Volvo 5-cylinder: How to Replace the Head Gasket
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
Jeffrie
Jimmy57 wrote the tool number at the end of this thread (see last post).
https://www.matthewsvolvosite.com/forums ... =9&t=49351
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
JWHunterinTN
Oh, we did leave it in the system after the treatment. The flushes were with the cascade cleaning at this point. Any thoughts on the cam locking tool? Going ot find an exhaust gas tester today if I can find one.
Jeffrie
MoVolvos
Post by MoVolvos »
Is this what you are looking for?
VOLVO Camshaft Crankshaft Alignment Timing Belt Locking Tool
S40, S60, S70, S80, S90, V70-2000, V70XC, XC70, V90, XC90
Used Once Best Offer
http://sfbay.craigslist.org/eby/pts/3078523299.html
Cam Tool.doc
(209.5 KiB) Downloaded 351 times
JWHunterinTN
We did leave the steel seal in the system, the flushing was done when cleaning with the cascade.
Any thoughts on teh cam locking tool??
Jeffrie
JWHunterinTN
It may very well be the tool in question. Have not seen one, but that looks like it will lock the two gears together.
Thanks,
Jeffrie
petax
Year and Model: 850 T-5R 1995
Post by petax »
Hi I have an indefinable leak, coolant is definitely getting burnt, sweet smell, clouds of steam on a cold start until warm. No cross contamination at all. You mention in this thread that you have tried "Steel Seal". Now I asked our cheerful chappy Scotty Kilner if he thought it would work on a 850T5R (aka Turbo), he said he had never seen it work, as there is too much pressure. He says the same about Normally Aspirated BMWs for that matter.
If you have tried it, what is your report? I would love it to work, I have just bought the car at collectors price, it is in excellent general condition, so you can imagine €2k or more workshop repairs on it are more than I can bear. Before I waste €90 on Steel Seal, I would very much appreciate some feed back from a real world test on a Volvo Turbo.
Thanks in advance, I really need this information, so please let me know.
1995 Black 850 T-5R Saloon 210,000 kms
