It's two more hoses and a metal manifold across tha back of the engine on my 99 HPT.
I recently degreased so will try to take a picture.
DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hoses
Replace Coolant & Radiator Hoses 1998 S70 GLT
- Has thanked: 1506 times
- Been thanked: 3818 times
Re: DIY: 1998 S70 GLT Turbo Coolant Hoses and 2 Radiator Hos
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
were you able to get the picture? i'm in the middle of replacing these guys but didn't do my research, so the turbo inlet hose listed in the first post is going back to FCP.abscate wrote: I recently degreased so will try to take a picture.
attached is what i've got from below, also on a 99 T5. i don't know which hoses i'm looking for. there's a whole lot of rubber down here and my wallet is frightened at the prospect of replacing all of it.
i think we've also got that oil cooler on the engine block, whose coolant hoses may need replacement. mine are not looking too good. anyone have a p/n and a source for these?
j-dawg
99+ owners, fyi: the oil cooler hoses pictured above can be had from IPD for ~25 each.
http://www.ipdusa.com/product.asp?P_ID=6947
http://www.ipdusa.com/product.asp?P_ID=6946
guess i get to wait for these to come in too, and suddenly i'm ~$60 poorer. still, it seems preferable to the oil line nightmare from the earlier cars.
does anyone know how the turbo coolant inlet hose or hoses look on a 99 T5? from what i can see, it looks like i have to remove the intake hoses from the airbox to the turbo in order to get at them (from above; they look more or less inaccessible from below).
Just a heads up to anyone who has not specifically looked at their turbo coolant inlet hose (and because of its location that may be many of us), check it out! It's easily seen from under the car. Because of heat and the oil that drips on it, it probably needs to be changed more than any of the other coolant hoses.
The left side of the picture is the skinnier end of the hose on my 855 and when squeezed feels like a ripe plum--real close to springing a leak. I already had the turbo air hose removed to make room for changing the heater core hoses which gave me access to the hose clamp bolt at the fat end of the hose. I had to remove the banjo bolt because the bolt on the hose clamp at the skinny end of the hose was so close to the top of the transmission I couldn't get a socket over it.
It's definately worth being aware of the health of this hose. I think I narrowly dodged a headache on this one. Thanks for the writeup!
- Been thanked: 472 times
Was checking underhood area today and noticed a slightly wet area at BLUE arrow.
Coolant in reservoir level is fine.
No coolant on the ground.
So I moved the clamp a bit to the passenger side so it "bites" on another part of the hose.
I remember reading somewhere that some people had corroded pipe issue, which I hope is not my case because replacing this metal pipe is not the definition of "fun" for me.
Anyone here has corroded pipe issue?
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Maybe a bit of hi temp silicon will seal it if all else fails. I inspected my hose, it's original and no weeping
For the turbo inlet hose (one closest to the turbo) do you need to remove the heat shield
For access? Can you purchase new copper o rings?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
The turbo INLET hose: no need to remove anything to replace it.
The copper washers: most repair books say replace copper washers, most mechanics I know and I never replace copper washers (unless it is damaged). These include oil pan drain bolts, banjo washers etc. I have re-used copper washers hundreds of times with zero issues.
Atis
- Year and Model: S70 GLT 1998
- Has thanked: 1 time
- Been thanked: 4 times
Yes I have... I have a parking heater and it has a huge steel pipe monster which is badly corroded. I am planning to take that out and put back an original heater hose until I fix the corrosion.cn90 wrote: Anyone here has corroded pipe issue?
By the way, do somebody knows the O-ring size of the firewall coupler?
On the issues of the Turbo INLET hose (sitting below Turbo) with oil dripping on it, causing it to swell. I am thinking out loud...
What if we wrap it in Aluminum foil, a few times to completely cover it, this way any oil will not touch the hose?
Mind you though, for me, the factory hose lasted 15y/150K without any Aluminum foil...
mecheng
I had a similar idea but it would easier if you use the aluminum foil tape used to seal ducts. At the very least I will put some silicon grease on the hose to protect it.cn90 wrote:On the issues of the Turbo INLET hose (sitting below Turbo) with oil dripping on it, causing it to swell. I am thinking out loud...
- 18 Replies
- 40809 Views
- 32 Replies
- 16018 Views
Last post by sleddriver
