The "unhandled exception..." is resolved with .Net Framework 3.5.1.
VIDA now says this:
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
VIDA/DiCE 2014D is now working, FINALLY! Is isoview 7 any better over 4 -- improved?
- RickHaleParker
- Been thanked: 979 times
Mixed results.
On my machine Isoview 7 results in some graphics problems. For others Isoview 7 is an solves some graphics problems ... the software/hardware/driver environments are different from one PC to another.
Give it a try, if it does not work out, uninstall Isoview 7 from the control panel then reinstall Isoview 4 from VidaDisk:\3PP\Products\isoview\ .
Active
Past
Past
xHeart
I'll switch from isoview 4 to isoview 7 and explore a little.
If it helps, I've a VIDA/DiCE 2014D running on Window 7 Ultimate with IE11. A repurposed and dedicated old HP with Intel Centrino for VIDA/DiCE only.
Does DiCE connected to ODB2 draw power from car battery when ignition off and key out, but remains connected to laptop over USB? I ask, because the battery voltage dropped to 8.4v overnight. It took a jump to start.
- RickHaleParker
DiCE draws power from the car battery via the ODBII port. The power line on the ODBII port is always on but does not draw power unless there is something is connected to it.xHeart wrote: 12 Jan 2019, 09:42 Does DiCE connected to ODB2 draw power from car battery when ignition off and key out, but remains connected to laptop over USB? I ask, because the battery voltage dropped to 8.4v overnight. It took a jump to start.
Active
Past
Past
Hi!RickHaleParker wrote: 19 Feb 2018, 11:21 On windows 10
1. Manually install .net framework 3.5.
2. Run scripts 1- 3, in the root directory of VIDA2014D_RePack.iso, one at a time.
3. Run the 2099 patch
4. Run Script 4
. Do not run Script 5
5. Reboot
6. Wait for Java to request a firewall exception.
7. Wait for Vida monitor to turn green.
If DiCE does not work correctly. Run DiCE setup in :\3PP\Products\DiCE\
Clean up: Uninstall Russian language Adobe reader and install English language Adobe reader.
Password: admin or 1 - 4 for specific Partner groups.
Just subscribed to the forum with a newly bought 2009 XC60 and trying to make vida work...
Where can I find the 2099 patch?
viewtopic.php?f=40&t=83834&start=130JoseBQ wrote: 19 Jan 2019, 07:50Hi!RickHaleParker wrote: 19 Feb 2018, 11:21 On windows 10
4. Run Script 4
5. Reboot
Found it!!!!
- RickHaleParker
The software the package that comes with a DiCE units often requires Windows 7 pro and IE9. You not going to use the software packaged that comes with the DiCE unit so just ignore that statement. This is why I push the RePack.
Active
Past
Past
So it doesn't matter which one I choose?RickHaleParker wrote: 19 Jan 2019, 20:40The software the package that comes with a DiCE units often requires Windows 7 pro and IE9. You not going to use the software packaged that comes with the DiCE unit so just ignore that statement. This is why I push the RePack.
- 8112 Views
Last post by jonesg
- 5289 Views
Last post by matthew1
- 4592 Views
Last post by Liliflower
- 10400 Views
Last post by nickbw898
- 2804 Views
Last post by xiami
