Good luck....lets carry discussion back to AC thread
https://www.matthewsvolvosite.com/forums ... 5&p=282688
If you are still having problems, so we don't pollute the IWOMCT thread here.
The I Worked on My Car Today Thread
2000 V70 Tailgate Trim Rattle Fix
- Been thanked: 4071 times
whoa
- Year and Model: 850 Turbo Wagon 1996
Cap & rotor. Noticed a small camshaft seal leak there, only 46K miles after putting a new seal in when I did the valve stem seals. Dang it. Plus I tore a plug wire distributor cap boot and lost a torx socket in the nether regions. Sometimes you feel like a nut.
1996 850 Turbo Wagon
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
The rear of the car with the old "normal" spoiler still fitted:
A draw wire installed to drag the spoiler brake light wiring through the tailgate which shows the routing of the cable:
Finally it is fitted and working:
A rare part that I had purchased and shipped from a breakers yard in Sweden, cost including shipping to the UK was £90 about $145 then I had to spray it which took a few days prior to it going on the car, I have been after one of these for a couple of years as the rear spoiler with integral brake light on the phase one V70 is a very rare accessory in the UK I have only ever seen one other - Mike
LASteve
- Year and Model: 2015 V60 T5 E-Drive
That spoiler looks fancy.
Yesterday, I went to the best U-Pick in Los Angeles.
After searching and searching, I found an 80% still there 99 S70 with a reasonable looking interior, so I went to work. New speakers, cup holders, pax front latch assembly, a few other odds and ends.
All for $36.
All for $36.
Current Sled: 2015 V60 T5 E-Drive
Volvos I used to own:
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
Heater core, coolant expansion tank, and driver-side sun visor.
I've done heater cores before on other makes, and this is one of those dread jobs that ordinarily strikes fear into one's heart, but on this car... holy cow that was easy. And cheap! Heater core $33.33 delivered, does not leak. Holy wow. The hardest part of the job was removing the plastic shroud under the motor to access the coolant drain plug, and that wasn't even really hard.
Love this car.
Love this car.
combatkarl
- Year and Model: 1997 850 GLT
Not all this weekend, but so far this summer.
Flush coolant- replaced radiator hoses, expansion tank hoses, upper turbo hose. Still to do - lower turbo hose and heater hoses.
Cap and Rotor- plugs were fine, wires are from 8/2011 so left those.
Drivers axle/cv & Axle seal- from EuroParts. Made in China unit so will monitor.
Replacement seats from '99 70 series. All electrics work. No SIPS
PCV replacement w/ 5/8" heater hose. Some vacuum lines replaced.
Tranny Drain and Fill x 1 - should do it a couple of more times as fluid was dirty/brown. Then attempt flush after several drain and fills.
Replaced starter with used unit while doing PCV.
Power steering fluid flush with Valvoline High Mileage Auto Transmission Stop Leak.
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
Ben850
- Been thanked: 7 times
Nice avatar photo Karl.
The '93 tail lights are not too bad in my opinion. I realize you have a '97, but cool choice of depiction.
It sounds like you are doing all the good things.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Today I removed both axles to replace inner and outer CV boots. Went quite smoothly, but the axle nut was a mission to undo! Still, I haven't found anything yet that won't eventually yield to my Bluepoint rattle gun!! Axles are in my bench vise awaiting surgery tomorrow.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Today I checked my bevel gear and rear differential fluids for colour and level; both came out full and clean at 190,000KM on original fluids. I plan on changing both of these fluids in the very near future.
Jesse
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- 21 Replies
- 6766 Views
- 955 Views
Last post by Craigd2599
- 1883 Views
Last post by rspi
- 820 Views
Last post by Clemens
- 26 Replies
- 6547 Views
Last post by ChadLee
