VIDA 2014D_Repack install on Windows 10, any version.
Crille
Year and Model: XC90
Post by Crille »
RickHaleParker wrote: 30 May 2021, 17:54 Decided it was time to bring all the install information together in one place.
Hi, I've had some trouble attempting to get this to work today. I searched the web and ended up here a few hours in, I tried downloading the torrent from this thread but it would never start downloading.
After a while I found another thread where you had shared another magnet link:
viewtopic.php?t=97243
I wanted to ask if that one is the correct one too? I could not find any scripts to run so I was thinking that maybe I had the wrong ISO?
Anyway I'll attempt a reinstall of the program now and see if I can get it to work this time. I had a few issues the first time.
Thank you in advance.
Edit:
After another test, where I installed the program, hit restart later and installed the patch, then restarted.
I'm met with:
"Please contact your local helpdesk
Could not contact central systems"
Edit 2:
I reinstalled Windows and tried again, this time after patching and restarting it worked! I must have done something wrong the first time.
huskerdooo
Year and Model: 1998 T5M, et al
Post by huskerdooo »
Hi All,
I went through these directions and all posts multiple times but I am stuck. Reinstalled everything 3 times with the same results.
VIDA loads but I have a blank area under the adapters (not red x, just whitespace). I did run VidaMedia:\Install\Utils\EnableIEHostingxxx.reg . for x64.
Running Win10 64bit. IE Tab loaded in Edge, all other scripts etc seemed to run fine.
My adapter is a JLR Mongoose clone V160 and I have the Drew Technologies drivers loaded. It seems to be fine in the device manager.
Any ideas on what to do to get the adapters to show up?
TIA
Edit: Well, I got it working on another laptop running Win7 using the Mongoose V160 clone provided files. I'd still like to get it to run on the WIN10 laptop if anyone has any information on how they successfully installed it.
1998 S70 T5 Manual, ARD Blue 19T, etc, etc, etc
2005 V50 i
2006 S60 T5
Stasiuss
Year and Model: 2013 Volvo XC90
Post by Stasiuss »
Hello dears, maybe a working link is available to download the latest 2014D Repack.iso?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Stasiuss wrote: 24 Jan 2023, 06:56 Hello dears, maybe a working link is available to download the latest 2014D Repack.iso?
The magnet link on page 1, 3rd paragraph is still working. Follow the instructions to download.
Active
Past
CincySoClose
Year and Model: 2009 S40
Post by CincySoClose »
I am still unable to log on to VIDA. I double checked the patch and it does have the correct date (2099) but there's something else that is preventing me from accessing VIDA from the Log on Screen.Like others, I receive the following message:
Unknown error. Please contact your local help desk Could not contact control systems.
Any suggestions for troubleshooting the situation would be greatly appreciated.
Thanks everyone!
Stasiuss
Post by Stasiuss »
When installing SQL 2008R2, no errors are displayed, but after checking "Microsoft SQL Server 2008 R2 → SQL Server Installation Center → Tools → Installed SQL Server features discovery report" shows that none. Tried several times going back to restore point but still the same. Where to look?
Stasiuss
Post by Stasiuss »
Now SQL is ok (should have tested Microsoft SQL Server 2008 R2 but not Microsoft SQL Server 2008). But VIDA threw an error during installation. Maybe this happened to someone?
sql error.jpg (7.72 KiB) Viewed 2496 times
VIDA not ok.jpg (11.71 KiB) Viewed 2496 times
hal9000f
Year and Model: 2013 V70 - 1997 855
Has thanked: 2 times
Been thanked: 3 times
Post by hal9000f »
Hi all.
I have searched and read all over.
Installed VIDA following instructions in this great thread - THANK you RickHaleParker :-)
I have VIDA 2014D Win10 installed on 4 computers (2 are VM installations).
Everything works fine including the DiCE connection on one (non-VM) laptop.
But, neither one shows any options for V70 MY2013 or V60 MY2012/2015 "Body Style" in vehicle profile, no matter what I choose in other selections.
The only profile which shows options for "Body Style" is for 850 MY1997.
Anyone has any ideas please?
TNX.
[1981 ... 244gld6 D24] - 1992. > 2004.
[1997 ... 855tdi D5252T] - 2004. > today.
[2013 ... V70d3 D5204T7] - 2022. > today.
RickHaleParker
hal9000f wrote: 15 Feb 2023, 10:37
No need for it. The body style is encoded in the model code. V in V50, V60, V70, V90 is for Versatility which are all five door.
The 850 came in two body styles 4 door and 5 door. There is no way to decode,which from the model code.
Active
Past
RickHaleParker
Stasiuss wrote: 01 Feb 2023, 07:30 But VIDA threw an error during installation. Maybe this happened to someone?
Error code 0x80004005
This problem may occur if a file that the Windows Product Activation (WPA) requires is damaged or missing.
This behavior occurs if one or both of the following conditions are true:
1: A third-party backup utility or an antivirus program interferes with the installation.
2: A file that WPA requires is manually modified.
Active
Past
