Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
vtl wrote: 18 Feb 2022, 15:01 It sounds like you have too much fun alone with your 720. I think, two more beers and I'll convince myself I need that 720 CEM on ebay =)
Ok, I almost bought it, but ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one instead ;) I feel my 8MHz Saleae knock-off limits me and for sure I need a 400 MHz logic analyzer that works with sigrok ;)
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
vtl wrote: 21 Feb 2022, 13:05 ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one instead ;)
It might not be a knock off. A lot of name brands are generics with a expensive name on them. Today it is marketing hype not the product that often determines price.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 22 Feb 2022, 13:13
I know. Either a rebranded generic device, or authentic device unofficially manufactured during night shift ;)
I liked a lot that with DSLogic you can easily write your own protocol dissector.
RickHaleParker
Sirloin took my hardware interrupt idea and ran with it. Added some of his own to the idea. It is getting good results.
Cracked with Calc_Bytes = 5, One range only, Samples = 10.
Candidate PIN 55 28 90 50 37 -- : brute forcing bytes 5 to 5 (1 bytes), will take up to 0 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..done
found PIN: 50 28 37 55 52 90
PIN is cracked in 1005.44 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Active
Past
RickHaleParker
Calc_Bytes = 5 : 1005.44 seconds ( 16.75 minutes )
Calc_Bytes = 4 : 814.80 seconds ( 13.58 minutes ) <== Sweet Spot.
Calc_Bytes = 3 : 1658.67 seconds ( 27.64 minutes )
Active
Past
RickHaleParker
vtl wrote: 20 Feb 2022, 10:17 - latency accumulation is very visible when the right subsequence is sent. 1 or 2 bytes don't make a difference, but 3 and, especially, 4 totally triggers it. Of course, CALC_BYTES=4 would be very slow on a 250 Kbps,
This applies to the CEM-B ?
If so, the 1 million 3 byte strings ( 3 bytes at a time ) in 1 hour 6 minuites at 250 pins per second.
( 00 00 00 XX XX XX - 99 99 99 XX XX XX ) not ( 00 XX XX XX XX XX - 99 99 99 XX XX XX )
Active
Past
sirloins
Year and Model: 2010 V50 T5 AWD M66
Been thanked: 3 times
Post by sirloins »
vtl wrote: 21 Feb 2022, 13:05 Ok, I almost bought it, but ebay showed me an ad w/ cheap DSLogic Pro knock-off, so I bought one instead ;) I feel my 8MHz Saleae knock-off limits me and for sure I need a 400 MHz logic analyzer that works with sigrok ;)
I have 3 P1 CEMs. I am sending one away, and I can send you one as well if you'd like. I have pretty much confirmed there is no difference between the 719 and 720 CEMs. I am happy to send you either a 719 or a 720. I think you can even flash a 719 with the files from a 720 without issue.
I do still plan to do the analysis with my logic analyzer, thanks for the sigrok reference, I had not seen that before. Although I have also mostly confirmed through trial and error that the timing issues all relate to the CAN interrupts, it would still be good to show once and for all.
vtl
Post by vtl »
sirloins wrote: 23 Feb 2022, 21:46 I am happy to send you either a 719 or a 720.
Thanks. I think it may be cheaper to buy it local.
RickHaleParker
RickHaleParker wrote: 22 Feb 2022, 19:31 Calc_Bytes = 5 : 1005.44 seconds ( 16.75 minutes )
Sirloin's code base keep getting faster and the reliability is looking good.
pin[3] choose candidate: 50
Candidate PIN 55 28 90 50 -- -- : brute forcing bytes 4 to 5 (2 bytes), will take up to 20 seconds
PIN is cracked in 493.06 seconds ( 8.22 minutes)
( 40% improvement in speed over the last one. )
Validating PIN
PIN verified.
done
Resetting all ECUs.
Active
Past
vtl
Post by vtl »
Yes, the very first software version cracked my CEM in under 5 minutes. It is much longer now for a reason :)
Once we figure out what's going on, the change will be happily applied.
