TisMe
Year and Model: 2001 & 2004 XC70
Has thanked: 42 times
Been thanked: 17 times
Post by TisMe »
RickHaleParker wrote: 24 Nov 2021, 20:39
TisMe wrote: 24 Nov 2021, 19:51 The strength of the "clasps" seem to not agree with a lot of my chosen beverage sizes.
Most countries don't serve the ridiculous American sugar junkie sizes. :wink:
Hah! Well when you order a large coffee, you expect a typical paper cup sizing. Not sure why Dunkin's iced coffee is trying to replicate the "Super Sized" options :roll:
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
TisMe wrote: 25 Nov 2021, 09:04 Not sure why Dunkin's iced coffee is trying to replicate the "Super Sized" options :roll:
True believers in the unlimited growth myth. :roll:
Active
Past
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
TisMe wrote: 24 Nov 2021, 19:51 The dashboard cup holder is cool, but I'd almost prefer the cubby.
It's a perfect place for a wallet and phone.
BlackBart
Post by BlackBart »
Last night I ordered a new set of Blizzak WS90 snows. All ready to buy from Tire Rack, and then I checked at Costco. There's a $150 off deal on this tire, so it beat TR by like 80 bucks. I really liked the idea of the Continental Viking just because it seems so appropriate on a Volvo, but the Blizzak is only a few dollars more and beats it in every category.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
This was actually a couple weeks ago but: almost ruined the Haldex casing when trying to get out a badly stuck Haldex oil pump.
Seems OK, it is not leaking after a week, but for example you can see the threads exposed where I chipped the casing. There are a few other gouges but appears ok. Now that I know it's not leaking I applied some silicone to hopefully prevent excessive corrosion of those threads moving forward.
chipped casing, but no leaks after a week
gooped up
gooped up
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
TisMe wrote: 24 Nov 2021, 19:51 The dashboard cup holder is cool, but I'd almost prefer the cubby. The strength of the "clasps" seem to not agree with a lot of my chosen beverage sizes.
Ridiculous, putting a cup holder next to electronics. . .
As if we don’t endure enough headaches stemming from electrical oddities on P2’s. I have to believe Volvo thought it amusing to suggest owners store their beverages adjacent to the radio/CCM/etc.
By the way, I just removed one of these stupid things & replaced it with the “pocket” (where boost gauges are supposed to live vs caffeine filled cups :) )
One clasp is broken off, but operates as it should & free to anyone who can make use of it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
wch2032
Year and Model: 06 XC70
Has thanked: 11 times
Post by wch2032 »
My car is making a metallic clanging sound whenever I pound on the front driver's side tire. Driving slowly, I think I also hear it on speed bumps. Any idea what it could be? The outer brake pad spring clip seems sturdy and in place, and I can't see the inner one easily. I don't think it's the hub, but maybe something else is loose?
Also, anyone have recommendations for a TPMS set? Or do ya'll with pre-07 cars just check the pressures regularly like I should be doing?
06 XC70 - 251K
RickHaleParker
wch2032 wrote: 08 Dec 2021, 12:00 Any idea what it could be?
Strut Mount.
1. Don a pair of heavy gloves.
2. Fix your eyes on the Strut Mount.
3. Grab the car by the fender well.
4. Bounce the car up and down.
Active
Past
Post by erikv11 »
Along those lines check the spring seat, they fail far too often. Pull the plastic cap and check the top nut on the strut tower - can you turn it with a wrench/pliers (if so then it's broken) or does it resist (as it should).
I'd also check the sway bar end links because they are a weak spot.
RickHaleParker
erikv11 wrote: 08 Dec 2021, 16:33 Along those lines check the spring seat, they fail far too often.
Spring seats , Strut mounts, if you replace one you might as well replace the other when you have it apart.
Active
Past
