Great news - I managed to install the plastic spacer on the tensioner!! I can't believe how tight the timing belt is!
And...the o-ring that I pictured with a few other washers (back a page or two) does indeed go to the breather (PCV) unit that attaches to the large hose connected to the throttle.
The plug/connector in the picture above that has an accordion type hose just below the connector attaches to the IAC valve. The other three-prong plug/connector is to the TPS sensor.
Still not sure where that black vacuum line attaches, but it is the one that goes under the airbox and into the firewall. I have the two vacuum lines that go to the airbox ready to attach once I install the throttle body gasket (due on Friday!).
Yet to install is the exhaust manifold and associated parts!
Appreciate all your help
