You don't need that tool unless you are investigating ways of speeding up the P3 hash collision.charlie13 wrote: 22 Apr 2022, 07:58 Thank you for your answer. I have all the diagnostics on windows. I don't have linux.
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- charlie13
- Year and Model: 2009 XC70
- Been thanked: 18 times
I have 11 hours and nothingcharlie13 wrote: 22 Apr 2022, 03:29Yes. I need a pin for I/0 but SMOK has limited functions. For this, teensy 4.0 complements the I/0 functionalityurosm wrote: 22 Apr 2022, 01:15But with I/O Terminal you don't have a crack CEM PIN, right?charlie13 wrote: 21 Apr 2022, 06:12
Still counts. I have a UHDS and an I / 0 terminal. UHDS counts slowly, I / 0 terminal does all CEM P1, P2, P3, SPA. That's why I / 0 is the better tool for me.
Just use it to read CEM flash and eeprom thru OBD, but first, you must find the PIN...
SEED c5 75 95, PIN 00 19 02 76 59, KEY 57 7a f4, 445 pins/s
SEED de db 20, PIN 00 19 02 81 04, KEY 4f c8 4e, 445 pins/s
SEED 72 fe a9, PIN 00 19 02 85 49, KEY 5b 11 9b, 445 pins/s
SEED 14 25 14, PIN 00 19 02 89 94, KEY 57 9a a3, 445 pins/s
SEED 9d 3b 83, PIN 00 19 02 94 39, KEY 34 14 fa, 445 pins/s
SEED 7b 22 7c, PIN 00 19 02 98 84, KEY b0 05 a9, 445 pins/s
SEED f3 4a 9c, PIN 00 19 03 03 29, KEY b5 7c 31, 445 pins/s
SEED 68 59 14, PIN 00 19 03 07 74, KEY cf 15 cf, 445 pins/s
SEED 72 d7 80, PIN 00 19 03 12 19, KEY 72 2e 36, 445 pins/s
SEED 3f 19 03, PIN 00 19 03 16 64, KEY a7 0a 02, 445 pins/s
SEED 27 95 97, PIN 00 19 03 21 09, KEY 8d e3 a7, 445 pins/s
SEED da f5 0a, PIN 00 19 03 25 54, KEY 77 a9 da, 445 pins/s
SEED 02 88 af, PIN 00 19 03 29 99, KEY aa 97 db, 445 pins/s
SEED af ba 30, PIN 00 19 03 34 44, KEY b1 45 d7, 445 pins/s
SEED cf 4f a5, PIN 00 19 03 38 89, KEY c7 57 e5, 445 pins/s
SEED 2c d0 d9, PIN 00 19 03 43 34, KEY 47 32 7a, 445 pins/s
SEED e6 83 40, PIN 00 19 03 47 79, KEY 5f 8b 00, 445 pins/s
SEED 36 ca d9, PIN 00 19 03 52 24, KEY 4d 89 35, 445 pins/s
SEED 4d 0c 64, PIN 00 19 03 56 69, KEY 93 ec 14, 445 pins/s
SEED f0 38 ed, PIN 00 19 03 61 14, KEY 07 a1 9f, 445 pins/s
SEED 86 e8 4b, PIN 00 19 03 65 59, KEY f7 b9 c0, 445 pins/s
SEED a7 4c ce, PIN 00 19 03 70 04, KEY da ee 9f, 445 pins/s
SEED 5f c1 bb, PIN 00 19 03 74 49, KEY 50 9b 66, 445 pins/s
SEED 0d eb c3, PIN 00 19 03 78 94, KEY ea 0f 86, 445 pins/s
SEED 36 17 04, PIN 00 19 03 83 39, KEY b6 8a 46, 445 pins/s
SEED 00 c6 e3, PIN 00 19 03 87 84, KEY 8b 28 31, 445 pins/s
SEED cb ed 03, PIN 00 19 03 92 29, KEY 4e 4b 26, 445 pins/s
SEED 07 a0 82, PIN 00 19 03 96 74, KEY 6b 23 b4, 445 pins/s
SEED 16 25 16, PIN 00 19 04 01 19, KEY a3 a7 05, 445 pins/s
SEED 9e 35 8e, PIN 00 19 04 05 64, KEY 13 19 3f, 445 pins/s
SEED bc 98 01, PIN 00 19 04 10 09, KEY 59 18 fb, 445 pins/s
SEED 49 f0 9c, PIN 00 19 04 14 54, KEY 08 c2 73, 445 pins/s
SEED 44 49 28, PIN 00 19 04 18 99, KEY ff c1 df, 445 pins/s
SEED c2 58 bf, PIN 00 19 04 23 44, KEY f4 15 aa, 445 pins/s
SEED 77 7a 28, PIN 00 19 04 27 89, KEY c0 02 34, 445 pins/s
SEED 7c fd a4, PIN 00 19 04 32 34, KEY 5c ae 51, 445 pins/s
vtl
The worst case would be a hit with pin 00 99 99 99 99, which would take almost 63 hours at your speed.charlie13 wrote: 22 Apr 2022, 10:20 I have 11 hours and nothing
- charlie13
Murphy's Law
Such events are normal?
SEED ce 21 ca, PIN 00 20 34 35 24, KEY 1b ab eb, 445 pins/s
SEED 7c 11 48, PIN 00 20 34 39 69, KEY 86 2a 9b, 445 pins/s
SEED 2e c3 c8, PIN 00 20 34 44 14, KEY 29 6a 32, 445 pins/s
canMsgReceive timed out, start 3301685844, now 3901685895, diff 600000051
p3_cem_get_seed: ugh...
CAN_HS ---> ID=00000726 data=ff ff ff ff ff ff ff ff
CAN_HS <--- ID=0000072e data=05 67 01 7a f2 ad 00 00
SEED 7a f2 ad, PIN 00 20 34 48 00, KEY a0 4c 3e, 386 pins/s
SEED dc 3e c7, PIN 00 20 34 52 45, KEY 59 f0 5e, 445 pins/s
SEED 39 45 59, PIN 00 20 34 56 90, KEY 48 c5 00, 445 pins/s
SEED b6 72 e1, PIN 00 20 34 61 35, KEY c5 22 4d, 445 pins/s
SEED 65 21 61, PIN 00 20 34 65 80, KEY fb 7c 50, 445 pins/s
SEED 87 2a 88, PIN 00 20 34 70 25, KEY c1 70 9d, 445 pins/s
SEED 66 52 11, PIN 00 20 34 74 70, KEY 70 42 0a, 445 pins/s
SEED 40 c3 a6, PIN 00 20 34 79 15, KEY af a9 74, 445 pins/s
SEED 90 77 c2, PIN 00 20 34 83 60, KEY 45 32 23, 445 pins/s
SEED 09 9f b3, PIN 00 20 34 88 05, KEY fc 8a b7, 445 pins/s
SEED f4 39 e8, PIN 00 20 34 92 50, KEY a0 b4 d3, 445 pins/s
SEED 41 37 53, PIN 00 21 86 18 05, KEY 31 12 a1, 445 pins/s
SEED c1 07 e3, PIN 00 21 86 22 50, KEY 00 8c 9c, 445 pins/s
SEED 63 2d 6b, PIN 00 21 86 26 95, KEY 6f 7a dd, 445 pins/s
reply: 02 67 02 00 00 00 00 00
hash collision found
SEED 6a f4 bb, PIN 00 21 86 28 06, KEY 63 44 9a, 111 pins/s
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
GAME OVER !
vtl
Sort of. Ugh is ughcharlie13 wrote: 22 Apr 2022, 11:09 Murphy's Law
You can start with PIN 00 20 ..., set p4 iterating from 20 here: https://github.com/vtl/volvo-cem-cracke ... .ino#L1137
- charlie13
CEM with us are cheap from $ 8 to $ 150. I can send. I think I am doing something wrong because it starts from the beginningvtl wrote: 22 Apr 2022, 11:33Sort of. Ugh is ughcharlie13 wrote: 22 Apr 2022, 11:09 Murphy's Law
p3_cem_get_seed: ugh...I haven't played much with P3. They (CEMs) are expensive, and it looks like I have to buy all those varieties in order to bullet proof the code.
- 9067 Views
Last post by RickHaleParker
- 8915 Views
- 27 Replies
- 27862 Views
Last post by cn90
- 10361 Views
Last post by jonesg
- 5535 Views
