Vida 2014D Times out 12/31/2017 23:59 Topic is solved
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
xHeart wrote: 10 Feb 2019, 09:55 No. But happy to try.
I am not suggesting you go get one of them minis. As I tried to point out before, it clear you have a non standard DICE with a non standard interface. I don't expect the non standard DiCE to work with the DiCE software. 2014A has nothing to do with the DiCE hardware, 2014A is a software version for VIDA. It is likely that that the 2014A software you got with your DiCE was patched to work with the non standard DiCE interface.
The DiCE software does work with DiCE clones that stick with the original DiCE interface standard. Some of the cloners tried to cheapen up their product by deviating from the original design, I think you have one of these.
Active
Past
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Rick, am to replace just the DiCE or look at eBay for a complete and newer VIDA/DiCE 2014D?
JoseBQ
Year and Model: 2009 XC60
Post by JoseBQ »
I enabled the operation in chrome, and it works in chrome!!! (through IETAB)
The problem is I hardly read anything because everything is so small!!!
Why can't I get it working in IE11 and it works in Google Chrome??? (I checked and I have .NEt 3.5 working)
RickHaleParker
JoseBQ wrote: 10 Feb 2019, 15:08 I enabled the operation in chrome, and it works in chrome!!! (through IETAB)
Hold down the [Ctrl] key then play with the [-] & [+] keys.
Active
Past
RickHaleParker
xHeart wrote: 10 Feb 2019, 13:49 Rick, am to replace just the DiCE or look at eBay for a complete and newer VIDA/DiCE 2014D?
I think you need a different DiCE.
Active
Past
JoseBQ
Post by JoseBQ »
RickHaleParker wrote: 10 Feb 2019, 17:01
Already tried, but doesn't work.
It only changes size of headlines.
That's what I think that working directly in IE (not through chrome) may allow me to change font sizes.
Any idea why it works on chrome and not on IE? How to change font size?
RickHaleParker
I tried over riding the VIDA font size in IE11 and Chrome, neither one works. Zoom appears to be the only option.
Active
Past
xHeart
Post by xHeart »
RickHaleParker wrote: 11 Feb 2019, 14:51 I tried over riding the VIDA font size in IE11 and Chrome, neither one works. Zoom appears to be the only option.
Unless otherwise revised, an application opened in a browser are INDEPENDENT of browser's, e.g. IE, use of font description for its interface. Web-based standard applications (assuming VIDA is) will pull the "font description" from the internet if connected.
These description files are either truetype, type1 or opentype. Alternatively, an application missing or unable to access font description may look to its OS for font substitution. The substitution will then make a reference font available. The standard reference font size use to be 6pt and/or 7pt -- reference fonts were not scalable.
I am suspecting it is a "missing font description" situation.
xHeart
Post by xHeart »
RickHaleParker wrote: 10 Feb 2019, 17:02
I could. Should I ask someone here at MVS if they have just DiCE for sale?
RickHaleParker
xHeart wrote: 12 Feb 2019, 10:11 I could. Should I ask someone here at MVS if they have just DiCE for sale?
Volvo DiCE clone, Full chip set, Full functions, Supports J2534, Supports Volvo Protocol.
To top it off, the vendor not just a salesman, he is a Electronics Engineer with more than 15 years experience in car, truck and outboards diagnostics. It stands to reason he knows how to sort the good stuff from the junk.
Active
Past
