VIDA 2014D_Repack install on Windows 10, any version.
kekec01
Year and Model: my2000 V70
Post by kekec01 »
I will use Diagnostic tab when my car get back from repair shop. I just bought VX and I want to check the car for possible errors, plus I will have to refresh gearbox fluid and reset fluid counter.
hal9000f
Year and Model: 2013 V70 - 1997 855
Has thanked: 2 times
Been thanked: 3 times
Post by hal9000f »
kekec01 wrote: 15 Apr 2023, 02:25 I will use Diagnostic tab when my car get back from repair shop. I just bought VX and I want to check the car for possible errors, plus I will have to refresh gearbox fluid and reset fluid counter.
The answer to your problem with the message you've reported is probably here...
viewtopic.php?t=83904&sid=0509d0aae772e ... 8&start=10
[1981 ... 244gld6 D24] - 1992. > 2004.
[1997 ... 855tdi D5252T] - 2004. > today.
[2013 ... V70d3 D5204T7] - 2022. > today.
kekec01
Post by kekec01 »
That is exactly what I needed. Thanks!!
tdogg
Year and Model: 2006 V70R
Post by tdogg »
Alright, I'm new here but not a new volvo owner. I've had my sonic blue V70R for 13 yrs now.
I'm getting the dreaded no communication with tool issue. Initially it was a blank with no X, then I manually updated the registry and now I have a box with an X but it still doesn't recognize anything.
I'm running Vida on a windows 10 home machine (fresh install).
I'm running it through Edge with the IE compatibility mode.
I have a V160 JRL pro data cable and downloaded the driver from OPUS website.
I'm at a loss as to what I need to do to fix this? I've never had VIDA/Dice before so this is my first time trying to connect. Thanks in advance for any help.
Cheers,
Toby
kodac
Year and Model: XC70 2010
Post by kodac »
Hi
Thanks for a great tutorial
Still having some issues
Think I have installed everything right but i can't type anything in the user box and the login is darkened out 🤔
What did i mess up?
Regards Christer
Treiku
Year and Model: s60 2002
Has thanked: 1 time
Been thanked: 2 times
Post by Treiku »
tdogg wrote: 27 Apr 2023, 22:32 ...
Did you use the registry update file mentioned in the installation guide or changed the values by yourself trough regedit? There shouldn't be any "x", only a drop down menu where dice (or other) device is listed. If there's no device listed under the drop down menu it usually indicated problems with drivers. I can't help you further but sometimes restarting the system helps after installing drivers.
kodac wrote: 09 May 2023, 14:42 ...
You're probably not using internet explorer (Microsoft forces you to use EDGE for quite some time now). If you're using EDGE open the drop down menu from top right (three dots) and choose "Reload in internet explorer mode".
Now to my own question: Everything works, I can read fault codes, erase them, have access to EWD and so on, but under vehicle communication I can't enter into modules to run activations and see running parameters. I can click on the module, but nothing happens. I've tried IE TAB aswell, but same problem.
The problem is intermittent, it starts working out of the blue and stops few minutes after. 95% of the time it doesn't work. No problems so far when using VDASH.
I'm using win 10 with EDGE in IE compability mode.
Edit 1: Did a quick test with XP virtual machine using IE7 and everything was working as it should. The problem probably lies in EDGE compabity mode. I'll try to re-enable IE on win10 and see how it goes. I'll edit this post after tests.
sangcXL3
Year and Model: 2006 XC90
Has thanked: 1 time
Post by sangcXL3 »
RickHaleParker wrote: 30 May 2021, 17:54 Decided it was time to bring all the install information together in one place.
Files you need.
2014D_Repack.iso
Patch 2014A-B-D-2099.zip
Click the link above to get the 2099 patch. Upack it to a folder.
To get the 2014D_Repack.iso Copy the magnet link in the line below to your clipboard.
magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d
In qBitorrent go to File on the menu then select Add Torrent link.
In the box start a new line and paste the magnet link from the clipboard.
Click download.
Other bittorrent clients have a means to manually add the magnet link.
1. Manually install .net framework 3.5.
  • Control Panel\All Control Panel Items\Programs and Features\Turn Windows Features on and off\ Check mark the box for .Net Frame 3.5. Click [ OK ] wait for .Net Frame 3.5 to install then reboot.
    While you are there enable Internet Explorer 11 if it is not enabled
2. In Windows File Explorer navigate to the 2014D_Repack.iso. Select, Left click then Mount.
  • The iso will show in the right panel as a DVD drive.
3. Run scripts 1- 3, in the root directory of VIDA2014D_RePack.iso, one at a time.
4. Run the 2099 patch
5. Run Script 4
  • . Do not run Script 5
6. Reboot
7. Wait for Java to request a firewall exception.
8. Wait for Vida monitor to turn green.
9. In Microsoft Edge install the extension IE Tab. Use IE Tab to open http://localhost/Vida/ this will take you to the VIDA login in page. Approve the install of the IE Tab helper program. How bookmark the VIDA login page. From now on use the bookmark to startup VIDA.
There is also a IE Tab for Google chrome. You can use it to operate VIDA in Google Chrome.
  • Note: Do not uninstall IE11. IE Tab uses the IE11 rendering engine.
10. Password: admin or 1 - 4 for specific Partner groups.
Clean up: Uninstall Russian language Adobe reader if you are not going to use it.
You can delete the short cuts on the Desktop.
If DiCE does not work correctly. Run DiCE setup in :\3PP\Products\DiCE\
If you get a X in the interface box.
Run VidaMedia:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems.
xxx =x86 is for 32bit operating systems.
Thank you! Ive managed to remove my old vida on w7 with fresh install at w10 with said steps
menyayto2
Year and Model: 2011 S40
Has thanked: 9 times
Post by menyayto2 »
Hello, I install the Repack on Windows 10 pro laptop, install Script #3 & patch in C:\
I could not write 1 or admin in the Login field, I open Vida in Internet Explorer mode, any advice Please
Thank you
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
menyayto2 wrote: 15 Jul 2023, 06:15 Hello, I install the Repack on Windows 10 pro laptop, install Script #3 & patch in C:\
.net framework 3.5 installed ?
Vida monitor icon green, yellow or red?
Active
Past
menyayto2
Post by menyayto2 »
Windows 10 pro fresh install, Netframework 3.5 installed, Vida monitor green icon.
I extract the patch manualy in C:\ by "old way", it is the same: I cannot enter anything in Login field.
Please help
