gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
vtl wrote: 03 Jun 2022, 19:25 Why? What happened? A crash or it just clicks annoyingly?
Bad wiring. Looks like it was cut somehow before I bought the car. I have a used SIPS with good wiring all the way to the plug to replace it with.
crazycat
Year and Model: 2005 xc70
Has thanked: 17 times
Been thanked: 6 times
Post by crazycat »
Trying to remove turbo heat shield, I broke one rusted bolt off, the long lower one on the passenger side. DOH!
Got driver side upper off at least. Now the lower /hidden bolt on the driver side is still seized and has me concerned. I hit them with PB Blaster for the past couple days but they all look super old and rusty. I guess if I have to do the head gasket at least I will be able to remove the broken one(s). I'm chasing a ecm-6805 overboost. I think my waste gate is stuck closed or the actuator is bad. I can't move the actuator at all.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
You can use VIDA to test output to the TCV. I assume you already tried replacing that though.
04s60 2.4
04xc70 2.5t
crazycat
Post by crazycat »
Yes I did test it, though I’m no pro at interpreting the data. Haha. I installed a new manifold pressure sensor $59 - no change and replaced the TCV (turbo control valve) again for free thanks to FCP warranty - no change either. Checked all vacuum lines, they seemed ok, and will replace those next as well. But when grabbing the Wastegate actuator arm I can’t budge it at all. Turbo has some axial play, I think too much, and I’m facing a possible head gasket replacement, so the snowball is building. Even with head gasket issues car was running well till I let it sit for a few months this winter.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Phone pic posting test......
Xmas on a Saturday -
Sideways, but it’s ok, you get the idea.
BlackBart
Post by BlackBart »
It’s like Pavlov’s dog - you see that blue tape And say Ooo, car parts!
Whoa, these subframe bolts are big!
gnalan
Post by gnalan »
Swapped out my driver's seat SIPS. I'm hoping the SRS module will be happy and finally turn off the light on my dash.
The 2001 is the one with the cut wires I removed, and the 2002 is the one I replaced it with. Easy enough job so far, but I haven't plugged it in yet. I'm too sore to do anymore today.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
2004 v70 makes clacking noise up front when i back out the drive way, I had some new sway bar end links in a box the past 2 years so i installed them, had to cut one off , no more clacking and knocking noise.
Next up is front brake hoses.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Hot today and with the 08 sitting in the sun broke out my gallon jug of Lexol and gave the black leather a good rub down. Interior is in great shape for 140k miles but was a bit on dry side when I bought it so this is the second time in a few months to bring some moisture back.
08 C702.5T (sold)
The non-Swedes:
gnalan
Post by gnalan »
Unhooked the battery, removed it, and ziptied the negative and positive terminals together. Unbolted the driver's seat to get to the wiring under the seat easier. I was able to lean the seat back far enough to swap out the cut SIPS harness with the uncut harness from the SIPS I installed yesterday. Put it all back together, key in position II, then hooked up the battery. None of the switches worked on the interior lights, and no door locks, possibly other issues I didn't check. Climbed out, locked the car with the key, unlocked it, and all is working again.
I still can't get the SRS light to turn off, even though VIDA is showing the old faults as green now so it should be fixed. :?:
I did lose my seat memory spots, so I'll have to play around with it until I get it back to the comfortable spots I had it in before. (Driving, relaxing when working with VIDA/DiCE, and the occasional nap, are my usual three settings.)
