Ac evaporator large leak
Has thanked: 1611 times
Been thanked: 4071 times
I could be wrong on this stuff. I’m living in V70 world and 850 HVAC might be different ?
I thought the internals were the same.
Pictures in my very first post in MVS 😁
Has thanked: 2207 times
Been thanked: 1852 times
Cases are different, can't recall by how much, but the quantity and position of some of the heating system servo motors are different as are the internal flaps.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
scot850 wrote: 12 Jul 2022, 11:15 I don't mind being wrong, but I think the section of the housing where the evaporator can be opened without removing the whole heating system with long Torx screw drivers or attachments.
That would be nice...mostly because i don't know where to find o rings for heater core.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Misha does your 850 wagon have ECC heater controls or MCC?
Strangely, when I look up Volvo parts lists they do not show an 'O' ring for the end of the pipe to the heater core for ECC systems. Volvo sells an 'O' ring kit but it is not clear if that is just for the bulkhead or if it includes 2 rings for the heater core. I do recommend if you can get OE rings as I have had issues with aftermarket ones leaking. They always seem to be thinner than the OE ones.
FCP Euro shows this for 97 850:
https://www.fcpeuro.com/Volvo-parts/850 ... ter%20core
misha
Post by misha »
I have ECC...but heater cores should be the same for both.
I allready surfed through FCP site in search for those o rings.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
So the ones I linked are not correct?
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
Pat Callaghan Jr.
98 S70 GLT
You can look in the master o-ring thread …..
viewtopic.php?t=88579&hilit=O+ring
Heater cores for MCC and ECC are the same
misha
Post by misha »
scot850 wrote: 12 Jul 2022, 17:43 So the ones I linked are not correct?
I didn't said that,Neil.
I just said that i allready surfed across FCP for those o rings and wrote down part #.
It says that o rings are for heater core/hose.
So...i don't quite understand are they for both aplications...for quick connect hose from firewall side or just for heater core connection from inside the cabin.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Misha, the huskies bumped a good thread on these orings for you
