Negative battery cable repair or replacement
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Thats interesting just one thing. That post connector with the blue wires looks like the wrong one for that terminal because it is closed so much. Cant argue if it works though
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Looks Nice. And as far as the wing vs hex nut,amblerman wrote: 06 Sep 2022, 18:00 back in 8/2019 I decided to replace all my battery cables and I went the route of making my own.
I didn't look on amazon for fancy batter cable terminals (wish I did) but ended up going with this set up.
This set up has been working fine for over 3 years now but probably < 10K miles as I drive so little theses days.
I sourced the red wire and lugs from West Marine. I ordered the blue wire online for the extra 5 hp/ft the Polestar blue color gives me.
it would have been cheaper to just buy pre-made cables but I enjoyed the project. We'll see how long this lasts me.
Note I did install a proper cover over the + terminal as part of the project.
Th wing nuts seem to be holding fine but I think I should swap those out for proper nuts.
One nice aspect of this type of terminal block is I can disconnect the negative side without removing terminal form the post. That remains tight and I just have to remove the wires and then tuck them behind battery.
-A
the studs will never know the difference.
As a wise man once said, if it ain’t broke...
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
yes I noticed that when I posted the picture the other day. Truth be told I never noticed that while under the hood.MrAl wrote: 07 Sep 2022, 02:58 Thats interesting just one thing. That post connector with the blue wires looks like the wrong one for that terminal because it is closed so much. Cant argue if it works though![]()
it absolutely is making good contact and since I am not taking the terminal off, I never have to deal with trying to wedge it back open.
I never even gate the size of the terminal a thought until after reading your comment.
- amblerman
my only thought on this is I could get it tighter with a wrench vs just my fingers on the wing nut. BUt it seems to be holding fine.BEJinFbk wrote: 07 Sep 2022, 09:53Looks Nice. And as far as the wing vs hex nut,amblerman wrote: 06 Sep 2022, 18:00 back in 8/2019 I decided to replace all my battery cables and I went the route of making my own.
-A
- Has thanked: 1611 times
- Been thanked: 4075 times
If you can’t twist the lead on lead terminal with wrist pressure they are in good contact. Any tightening after that just squeezes the lead around more. It’s fine, just leave it.
- MrAl
Yes i think one terminal is slightly smaller diameter than the other maybe? i havent checked for this in a long time.amblerman wrote: 07 Sep 2022, 11:55yes I noticed that when I posted the picture the other day. Truth be told I never noticed that while under the hood.MrAl wrote: 07 Sep 2022, 02:58 Thats interesting just one thing. That post connector with the blue wires looks like the wrong one for that terminal because it is closed so much. Cant argue if it works though![]()
Dont use a metal ruler
