Correct, the serrations on the arm form to the harder motor stub. There is a torque for the nut but can't recall what it is. I will try to find it for you. It is 16Nm, or 12 ft/lb for front and rear arms on wagons.
Tried looking up the air vent valve. The pictures on the Volvo websites are not helpful in the slightest! All you see is a smudge!
EEuro picture is much better. So just a plastic can with a one-way valve in it?
wiper arm stud - spline worn, arm does not hold
- Has thanked: 2198 times
- Been thanked: 1851 times
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
But the arms are on a diagonal, so at what point do I measure?
Or do the V70 arms somehow stay parallel to the bottom of the glass?
I'm just gonna wing it as usual...
NEVER OPEN THE HOOD !!!
Looking at on-line pictures helps to get a good position and then mark with tape on the windshield. Once the splines are cut into the arm on tightening you can always remove it and reposition if for example the rest position changes during use.
Take the opportunity to lube all the motor joints it is amazing how much smoother they run with some love!
Here is what I consider a good rest position for the arms:
https://www.bing.com/images/search?view ... ajaxserp=0
850forum
NOW he tells me - after its all back togetherscot850 wrote: 16 Sep 2022, 16:12 Take the opportunity to lube all the motor joints it is amazing how much smoother they run with some love!
- 1864 Views
Last post by RyanJohnRyan
- 14 Replies
- 1545 Views
Last post by Krons
- 18 Replies
- 3186 Views
- 809 Views
- 1027 Views
Last post by dsharp
