failing alternator or belt?
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
even better- thanks.. Will I get much leakage from the power steering pump fitting?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Maybe '01 was different but I believe you may have to remove the A/C compressor bolts to get the alternator out also. My '03 was that way.
2003 XC 70 (sold)
azureblue
as long as I don't have to pull the AC comp.. I don't think I have to. I may have to move the engine computer box over to get a little more wiggle room. Fortunately, I have an enclosed garage
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Alternator bottom bolts are shared with A/C compressor upper bolts. Need to slacken the lower A/C bolts.Blacklab467 wrote: 15 Dec 2022, 10:30 Maybe '01 was different but I believe you may have to remove the A/C compressor bolts to get the alternator out also. My '03 was that way.
vtl
Some. Get a box of silicone plugs: search "OPK12 Rubber Vacuum Cap Assortment" on amazon, these fit into both ends of disconnected high pressure line. You'll have almost no leaks, only in the moment when disconnecting the line from the pump.azureblue wrote: 15 Dec 2022, 10:26 even better- thanks.. Will I get much leakage from the power steering pump fitting?
- 20 Replies
- 7473 Views
Last post by tonie
- 1051 Views
Last post by vtl
- 13 Replies
- 2886 Views
Last post by obayha
- 3905 Views
Last post by precopster
- 1526 Views
Last post by frknvgn
