I appreciate you guys a lot. it's reassuring to hear from you. If there's no play and damage to the rubber boots, I'll leave it alone.famfeld wrote: 23 Feb 2023, 13:14 Repeating what was said above and I think may be going unheard. If it was aligned AND there is no play currently, leave it alone and worry about it next time you need an alignment, which hopefully is like 3 years from now. I often have to heat with torch to get them to turn. At pep boys they want the car done fast so that they can free up the bay and can't let it sit for a day with PB blaster sprayed a few times.
Feld
I noticed that after the alignment, my steering wheel and the car still did not track straight, s I'm a little concerned that there is some wear on the tie rods. But I'll check for play and make sure; maybe the shop didn't get it aligned correctly.
