07 XC70 jerky, then drivetrain does not engage, anti-skid light
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1498 times
Been thanked: 3810 times
Re: 07 XC70 jerky, then drivetrain does not engage, anti-skid light
I’m reading in a nasty failed CV joint from those audio symptoms.
The AWD is then going crazy since it’s detecting huge variations in wheel spin between front and rear?
Best and cheapest , and because the Creator loves Iowa , the most likely
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
scot850 wrote: 10 Feb 2024, 23:16
Is this a P2 thing? On the P80's with either the 2 or 4 bolt lower control arm I can't see how the axle could move outward or load the carrier bearing like this to move.
the control arm is bolted to the frame but the other end is only held by the ball joint stud.
if the ball joint is disconnected and the strut is jacked up by jacking under the knuckle , the strut will move outward because it can.
I suspect someone did that in the past with the driveshaft center bolt still in place and pulled the shaft from its fully seated position.
Its better to pull the control arm down than push the knuckle up to seat the ball joint.
Has thanked: 1836 times
Been thanked: 1709 times
I can see that. Just seems strange it has been driving fine and all of a sudden this happens. It is certainly a strange issue.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
abscate wrote: 11 Feb 2024, 04:13 I’m reading in a nasty failed CV joint from those audio symptoms.
CV seems completely fine by feel, now that the axle is out. It simply disengaged from the trans.
Agreed on the rest, AWD going nuts trying to keep the car going.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Post by erikv11 »
There’s no pothole involved it was going low speed when it failed. At any rate It wasn’t sudden it was gradual, the 1.5 cm of shiny surface at the transmission tells you that. It reached its limit suddenly sure. Pothole or forced-by-mechanic explanations don’t seem plausible.
Don't the CVs have enough lateral play to allow axle tip to back out of trans if there was slippage at the carrier bearing? We've certainly seen driver's side axles (no carrier bearing) backed out.
Also regarding suddenly: would be more accurate to say there was slight intermittent shimmy for a long time - see my earlier post about the peeing axle, it’s this axle viewtopic.php?t=103624.
No way in hell I’d reseat the bearing and use this POS unless under duress lol.
'06 S60 R, 197k
jonesg
Post by jonesg »
bearing holds it in alignment, the bearing shifted and allowed enough slack for it to pop out.
same as unbolting the carrier bearing in the prop shaft allows the shaft to disconnect from the angle gear.
Post by erikv11 »
Exactly
'06 S60 R, 197k
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
This issue has happened before.
In this thread, it is worth reading @jimmy57's post:
Bearing shift on my 3rd autozone passenger cv axle?
viewtopic.php?t=93189
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
erikv11 wrote: 10 Feb 2024, 13:17 passenger's CV dislodged due to slippage of the half shaft through the carrier bearing.
How many miles on that CV shaft Erik?
08 C702.5T (sold)
The non-Swedes:
Post by erikv11 »
Krons wrote: 11 Feb 2024, 18:56
PO paid $300 for the part from a Minneapolis Indy shop (Glasgow) so clearly an aftermarket part. Lifespan 08/2018-02/2024 and 124k-186k so:
62k miles
5 years and 6 months
'06 S60 R, 197k
