VVT Woes - 2008 S60 2.5T
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
VIDA is the answer to the ultimate question of Volvo, the Universe, and Everything.SKim wrote: 23 Apr 2026, 19:41 Replaced it with new one (Febi) from FCP, including new gasket. What is Vida…?
- Has thanked: 2856 times
- Been thanked: 1332 times
Here you go - what is VIDA?SKim wrote: 23 Apr 2026, 19:41 Replaced it with new one (Febi) from FCP, including new gasket. What is Vida…?
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Isn't 28 psi at idle low? My odb2 Bluetooth unit with torque app on my Android phone reports 43 psi at idle. I borrowed a pressure gauge from an auto parts store and saw the same, one time. I had thought the pressure should be higher but this seems normal for my 06 s60 2.5T.
Also, I've never seen oil bubbles on my dipstick.
At 185k it’s likely the VVT has worn out, causing that code. The car will run fine with a warn VVT as long as you can get it through inspection
- 5180 Views
Last post by LT South Africa
- 4207 Views
Last post by jimmy57
- 461 Views
Last post by goudgoud
- 12 Replies
- 14794 Views
- 372 Views
Last post by 1sd115
