Intake VVT Questions 2008 XC70
goudgoud
- Year and Model: 2008 XC70
Hi, I have a error code for my intake VVT solenoid. I have done quite a bit of research however I have some questions. I see two completely different replacement parts, some sites simply describe both as VVT solenoid however I found one site that says intake for the longer part and exhaust for the shorter. My question is I can find zero information, youtube video's etc differentiating these two parts nor can I find information on locating the specific parts on the motor. All I found was the location of the two exhaust solenoids on top of the motor by intake manifold located on the left and right side. Where do the intake solenoids sit and what's the procedure for replacing? Any help is appreciated!
goudgoud
Here is the intake part:
https://www.partsgeek.com/b68m3wv-volvo ... uster.html
and here is the exhaust:
https://www.partsgeek.com/rwp5lc5-volvo ... 9CEALw_wcB
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
What code are you getting?
The 3.2 is shared with Land Rover
Take a look at these links
https://www.freel2.com/forum/topic39176.html
https://www.freel2.com/forum/topic38702 ... ight=p0016
Good luck
Paul
The Intake has Variable Valve timing and Variable Valve lift.
Variable Valve Timing (1 solenoid per engine)
https://landroverforums.com/forum/lr2-35/p...le-113192/
30731116, Volvo
31251224, Volvo
36002690, Volvo
7G9N9M424AA, FORD
LR011224 LAND ROVER
Variable Valve Lift (2 solenoids per engine)
LR025967 Land Rover
31216281 Volvo
Good luck
Paul
- 5169 Views
Last post by LT South Africa
- 4191 Views
Last post by jimmy57
- 1197 Views
Last post by beigg
- 6057 Views
- 715 Views
Last post by DonnVa
