That’s a neat trick, I’d be interested in reading through that thread. I still have to drop the pan eventually, I’ve got a kit with new seals and it looks like the pan hasn’t ever been touched (safe for the nice dent on the underside)There was a thread where someone rammed stiff Pcv tube into the block hole and packed it full of carbon gunk, then cut that piece of tube off , rinse, repeat. This cleared the draft hole without dropping the pan
1998 V70XC - Oil Leak Puzzle
- VolvoOwl98
- Year and Model: 1998 V70XC
- Has thanked: 33 times
- Been thanked: 17 times
Lifted 1998 V70XC "Saskia" - Introduction/Continuing Repair Post: viewtopic.php?t=107993
- Chassis number: 475986 (early 1998 chassis dated 01/98)
- Emission code: 4
Learning and growing all the time
- Emission code: 4
- VolvoOwl98
Looked for a while to find it, wasn't able to find the discussion thoughabscate wrote: 26 May 2026, 13:51 There was a thread where someone rammed stiff Pcv tube into the block hole and packed it full of carbon gunk, then cut that piece of tube off , rinse, repeat. This cleared the draft hole without dropping the pan.
Once you get it partly open, bottle cleaning wire brush and routing to get it clean.
Maybe Mike alder from Australia wrote that up? It was someone famous
I did find this thought, viewtopic.php?t=53246, as well as the thread I earlier mentioned in passing for an improvement to the PCV system (viewtopic.php?f=1&t=53448#google_vignette which I'm thinking of doing for good measure also
I did some inspecting around, and there's still definitely a leak, but with the culprits in mind (and thanks to the blessing bestowed by some visiting family) there's numerous parts on the way (front and rear camshaft seals, front crankshaft seal, oil pump gasket/o-ring kit, and oil cooler line kit), with the goal being to install them after resolving the PCV issue
Two good bits of good news, one being that she's seeing fewer miles per week so that should slow issues becoming worse, and that upon inspection of the turbo oil return line it's as dry as a bone (thank goodness! I don't have to deal with that pain in the hands again)
I am certainly curious to see why crankcase ventilation tube (p/n: 9471644) that runs from the oil trap to the PTC valve has oil leaking from it, especially since the whole system was replaced when I bought Saskia. I am going to try abscate's advice of running a double gasket for the cap, as well as checking the fitment and clamp snugness of the PCV hose at the top of the head
(To clarify, I’m not going for a full timing belt and water pump servicing since that was done only 7k miles ago on 6/6/25 at a Volvo indie shop with FCP Euro KIT-517997 ( https://www.fcpeuro.com/products/volvo ... tbkit217wp) by the previous owner. Also the belt still looks to be in good shape)
- Emission code: 4
- Emission code: 4
- VolvoOwl98
Saskia's continued to be giving herself an oil change as time goes on, so I'm in the preparation stage to do the following:
- Front and rear camshaft seals,
- Front crankshaft seal,
- Oil pump seal kit,
- Dropping oil pan (replacing seals and cleaning out PCV passageway thingy)
- Re-tapping the drain plug for an M20x1.5 drain plug to replace the stretched threads (OEM M18x1.5)
- New M20x1.5 drain plug (304 stainless steel, CNC machined, copper crush washer, 5000 gauss neodymium magnet (link: https://hpsperformanceproducts.com/prod ... 2641806526)
For a 1998 V70XC, the following bolts are needed if you want to replace the ones securing the oil pan to the bottom of the engine block:
M7x40 - need 3 - p/n: 985322
M7x20 - need 22 - p/n: 985133
M7x100 - need 4 - p/n: 985324
(for the oil thermostat housing (p/n: 3528199) that, as I understand, diverts oil into an oil cooler built into the radiator, two six point socket screws (p/n: 986226) have to be removed (T40 torx), which has some discussion here: viewtopic.php?t=36007&start=30. It would probably also be a good idea to replace the seal (p/n: 1366791)
I already replaced the torque mount not too long ago, so that should be good. Will be buying new bolts for the exhaust camshaft position sensor, the old ones are stiff and seem ready to strip at a moment's notice... (p/n: 986226)
(Will also install new coolant expansion tank, cap, and silicon hosing for it (do88) since they have to be taken out anyway, and the expansion tank is developing internal hairline fractures
- Emission code: 4
- Emission code: 4
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
When I did my oil pan it called for a very thin coating of anaerobic sealant.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- VolvoOwl98
Yep, p/n: 259760jmartin919 wrote: 18 Jul 2026, 11:14 When I did my oil pan it called for a very thin coating of anaerobic sealant.
- Emission code: 4
- Emission code: 4
jmartin919
I used Permatex Anaerobic Flange Sealant
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- 797 Views
Last post by JimBee
- 1129 Views
- 183 Views
Last post by darylrobert
- 1361 Views
Last post by FLXC90
- 787 Views
Last post by Grover365
