S80 1G 6Cyl Auto Transmission Fluid & Filter Change How-To
This topic is in the MVS Volvo Repair Database » S80 1G 6Cyl Auto Transmission Fluid & Filter Change How-To
Stacy1226
Year and Model: 2000 S80 T6
Post by Stacy1226 »
There is some fluid leaking from the left boot. One mechanic said the seal needs replaced. Is this accurate and common on these type cars. Stacy
Mattvh
Year and Model: 2001 s 80
Has thanked: 1 time
Post by Mattvh »
If I wanted to change fluid more then one time, a. Should I drive it just a couple miles between ,and can I use non synthetic fluid to save money until the last fluid change. Thank you
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Mattvh wrote: 22 May 2019, 10:41 If I wanted to change fluid more then one time, a. Should I drive it just a couple miles between ,and can I use non synthetic fluid to save money until the last fluid change. Thank you
If you are that worried about getting the old fluid out than spend the couple of hundred dollars at Volvo for a fluid exchange otherwise there's write ups here on pulling a cooler line and run a "at home" exchange.
My experience with my 2004 S80 has been the Volvo brand Detron 3 works best. Walmart brand Dextron 3 caused harsh upshifts, Synthetic fluid covering Dextron 3 caused soft upshifts and late harsh downshifts. Volvo Dextron 3 brought everything back to normal. That's been my experience with my 4T65EV-GT in my 2004 S80 T6. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
No it's not necessary to change it several times. Please look at my recent transmission filter change, flush and Transgo Shift Kit installation.
viewtopic.php?f=11&t=88630&p=504849#p504849
