I just want to know if these statements are correct. I have a V70 GLT that is not AWD, so I have the 2 bolt control arms? Need to know because I need to order some....FCPGroton wrote:The C70 has the 4 bolt control arms also. I have never replaced them myself, but I have hear that they are a real pain in the rear.Ozark Lee wrote:I have never dealt with the 4 bolt versions, I think they are almost exclusively on the 4WD models. From what I have read on VADIS Wrenchinjoe is correct, the motor mount needs to be unbolted and the engine jacked up to gain access to the nuts on the inside frame rail for the 4 bolt style.
Any special tools needed to replace control arms?
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
A FWD V70 has the 2-bolt control arms.
'98 S70 T5
2016 Chevy Cruze Premier
OK, well I'm giving it a shot. I can't see paying $400 labor for this repair....
Current Volvos:
2004 C70 HPT (wife)
1998 V70 GLT (son)
2004 C70 HPT (wife)
1998 V70 GLT (son)
jblackburn
The hardest part (for me) is just getting the knuckle loose from the wheel. Since you're replacing them anyway, a good hard smack with something like a small sledge should do the trick. They also make little pickle fork things that may help you out.
http://www.google.com/products/catalog? ... CFQQ8gIwAg
'98 S70 T5
- LamboSE5
- Year and Model: Empty
Thank you for that link!!FCPGroton wrote:This is a good "How-To" for you. It should help you get the job done and no, you don't need any special tools.
HOW TO: Replace Worn Control Arms
- LamboSE5
Not happy to hear that. Just got fcp's little front suspension kit.djm850 wrote:I've had Scantech and Meyle both go bad in less than a year. Went back with Genuine and still holding up.
It has Meyle HD control arms and Meyle HD sway bar links... someone posted that Meyel HD is good.
- LamboSE5
Great to hear just before I attempt mine....Schmitty wrote:I just got both my control arms installed, it took me 2 days. I have a few tips for those in snowy climates where they use salt on the roads.
The bolt that keeps the ball joint in place will be so rusted that (in my case) an angle grinder was needed to cut off the control arm and cut the bolt in three spots. I then used a big hole punch and a hammer to punch out the shaft of the bolt that remained. It took me about 3 to 5 minutes of tap-tap-taping on it for it to budge loose and then finally come out. An angle grinder can be used to cut the bolts without cutting any other of the parts (I nicked a few here and there but not bad).
Oh, and also, I was using PBlaster on it for *days* and the parts weren't budging, so out came the angle grinder.
I live on a rock of salt..
How worried should I be about the whole not torqing down while still in air, bounce car first, etc factors, like lining up the arm with the door seam(?) as Ozark mentioned?
- Year and Model: Many Volvos
- Been thanked: 76 times
LamboSE5 wrote:Great to hear just before I attempt mine....Schmitty wrote:I just got both my control arms installed, it took me 2 days. I have a few tips for those in snowy climates where they use salt on the roads.
Oh, and also, I was using PBlaster on it for *days* and the parts weren't budging, so out came the angle grinder.![]()
Getting the control arm to, more or less, ride height is critical or it will tear the bushings out where they bolt to the sub-frame and cause a premature failure.
Even if you torqued them down in the lowered position you can always go back and do things over again. I normally buy new bolts for everything that is stretch torqued when I replace things but you are likely OK to re-use them if they were just recently changed.
I changed control arms on one of my cars (actually I have changed control arms on all them except the XC) only to have an axle crapping out a month or so later and I re-used the bolts after the axle change with no problems thus far.
The bolts (and nuts) are dirt cheap if you can get them from a local dealer or have time to wait for mail order and it is always preferable to just replace them with new and go through the torque procedure again.
burnout8488
- Year and Model: 1999 S70 AWD
Just did my 4bolt control arms. No need to lift the engine at all. Use a 17mm box end wrench and you will have enough room to access the bolts on both sides.
One bolt on the passenger side is obstructed. Put the wrench on that bolt. There is no room for your hand to crack it off counterclockwise, as it will be factory tight. Use a screwdriver or pry bar as a lever underneath the wrench by prying using the subframe as a place to rest the screwdriver on. This will crack the bolt free, I hope it described it well enough.
The control arm bushings will be tight, so you won't be able to thread the bolts straight into them as they will be at an incorrect angle. Use a vise grip to bend the bushing into the correct angle so the bolt can be threaded in straight. When you see the arms, you'll understand. Make sure the ball joint is bolted into the control arm at this point before you bolt the arm into the subframe.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- 19 Replies
- 5275 Views
Last post by erikv11
- 1818 Views
Last post by chaos26670
- 3394 Views
Last post by RickHaleParker
- 2749 Views
Last post by matthew1
- 11 Replies
- 5959 Views
Last post by Ozark Lee
