I may have misread one of the earlier posts, I removed the capacitor that was there on the OEM setup and let the speaker work as a full range speaker when I installed mine. I got confused since my Infinity's also had a capacitor going to its tweeter and that was the one I thought Os was talking about.
Dash Speaker Replacement
Volvo 850, S70, V70, C70, XC70 Dash Speaker Replacement
- Year and Model: Many Volvos
- Been thanked: 76 times
So Lee, are you saying you didn't connect those big-arse caps that were included with the infinitys in the separate bag?
I actually already popped my new speakers in this afternoon, and so far everything appears to be working. . .though I had a little trouble determining if I was getting sound at first due to their close proximity to the front door panel speakers. Cupped my ears and tried to muffle the door panels, and I heard beautiful sound coming from the dash
You think keeping the big caps on there will cause any ill effects?
1995 850 GLT Sedan, Nautic Blue
My set-up looks exactly like yours.mercharch wrote:So Lee, are you saying you didn't connect those big-arse caps that were included with the infinitys in the separate bag?
So far so good. I can definitely hear them
I did save the original caps though just in case.
Now I'd like to replace the other speakers as well, but have a bad wheel bearing, stage 0 and maybe PVC to do first!
-os
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
Ordered these speakers recently and installed them today. Easy as pie. I de-soldered the factory connectors from the stock speakers and soldered them to the new speakers. I did not use the extra-large caps, as the specs of the cap in-line with the Infinity's matched the specs of the factory caps. To mount them, I used some spare trim screws I had around that came with a v-shaped metal clip I slipped over the one hole that lined up to screw in to. I used short self-tapping screws to get a second anchor point, and they tightened up nicely. Sounds good so far! Thanks for the tips. Anyone have a similarly cheap and easy replacement for the rear pillar speakers in the wagon?
rw_stebbins
- Year and Model: 850 1995
As far as mixing 8 & 4 ohm speakers... I've corresponded with the Crutchfield Tech Staff. They say there's no problem with mixing them.
- 986 Views
Last post by Paul-93-850
- 1300 Views
Last post by rasense
- 580 Views
Last post by Ozark Lee
- 727 Views
Last post by gordo850turbo
- 1271 Views
Last post by JRL
