Ah. Grab the grey plastic part forward of that and pull it off. I think that's how it's supposed to be.
The 850's is just black. I wish I could remember what it looked like on the S70, but I think you just pulled the cap off the end of it.
http://www.google.com/url?sa=t&rct=j&q= ... UkxGxKWJDA
Volvo 850 Ignition Switch Replacement
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
- LamboSE5
- Year and Model: Empty
looks like from that picture you posted that the grey plastic piece is part of the switch/the metal. Do you mean grab the grey part (with something) and pull off the beige part that is sliding in the video? It just seems like if the beige part comes off its gonna rip off the wires that are soldered to those posts.
I'll try anyway, i've had enough with this part.
Nolander57
- Year and Model: 850 / 1997
ALERT!!! I forund the two deep set screws on my cover to be T-15 and not a T-25, after spending an hour trying to line the 25 up I started trying different sizes, and the T-15 was the fix. FYI
1997volvo850
- Year and Model: 1997 Volvo 850
My HarborFreight T-25 doesn't work on the 2 deep screws. Unfortunately my T-15 driver (3" shaft) is shorter
than the 3.5" required reach the screws and my small T-15 socket gets stuck. Off to buy a T-15 with a longer
shaft...not sure if Harbor Freight sells these with a longer shaft. Any suggestions are welcome.
David
David
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
To avoid the issue of loose connector pins, sparks,
arcs and trying to figure out which pin goes back where,
leave the cap on the ignition switch connector in place.
It's the only thing that holds all the pins in place.
The pins all fit very tightly, so it's not the easiest connector
to seperate, but it will unplug. You may find it easier if you
remove the contact block from the column first. Your call.
The entire plastic connector body unplugs from the switch.
This is what it should look like unplugged: It should all disconnect from the contact block at the back of
ignition switch assembly as one part with all the pins retained.
If your connector looks like this, then the cap has been removed: If you unplug it with no cap, the wires and their pins will all fall out
and sadness follows. Especially if you didn't disconnect the battery...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
kanguru007
- Year and Model: 850 1994
The upper bolts on my 1994 2L NA 20V wagon are T10 instead of T15 or T25!!!
The ignition switch that is not returning to the correct (lights ON) position can be repaired to as-good-as-new condition and will probably last for another 20 years: open it and use pressure-pliers to repeatedly squeeze the spring-loaded metal pad to make it about 1mm wider (sorry I didn't take a picture)
- 1487 Views
Last post by chuffin hell
- 20 Replies
- 2111 Views
Last post by MoVolvos
- 2040 Views
Last post by DoggyB22
- 21 Replies
- 9087 Views
Last post by jexy9
- 12 Replies
- 17801 Views
Last post by Saimon3
