... this thing is always going to leak ..MVSUCCESS !!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Sorry I haven't been keeping track of any threads lately. That hole is normal. 1993 and some 1994 models had a crankcase ventilation hose there. The hole is just there as a remanant, and it is sealed off from the inside.
It does look like your oil cap seal to me.
I think I fixed it last weekend, but haven't had a chance to pop the hood when it was light out until a heater core hose burst almost completely through on me in the middle of the highway 2 days ago, leaving me driving a friends car until this afternoon.
Fix one leak, it leaks something else. Just how it does things I guess... :roll:
And it's Justin btw ;)
'98 S70 T5
2016 Chevy Cruze Premier
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
Sorry JUSTIN :roll: . I get call Shawn all the time.
Sorry to here about another problem with yours.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Epicsurf
Year and Model: 850 T 1996
Post by Epicsurf »
Justin: What do you mean it is sealed off from the inside? Mine clearly goes through since after I took this picture and drove it, it filled back up with oil. That is why I am sure this is where the oil is coming from. Can I seal this off with RTV?
Epicsurf
Post by Epicsurf »
Anyone know more about this? The smell is killing me! I am ready to fill the hole with sealant.
jblackburn
There is (supposed) to be a gasket sealant on the inside of the cover for the port on cars that it's not used on. I'd say the RTV is worth a shot.
'98 S70 T5
turbozutek
Year and Model: 1995 850 GLE
Post by turbozutek »
The sealant might work, but I'd personally be tempted to make a plug out of cork and secure it as a plug with the two screw holes at either side (looks perfect for a strip of Mecano or a couple of large washers!) and then see if there's still oil everywhere.
That'll confirm it's definitely the leak site and also you can RTV the cork (or metal or whatever you use for a plug) in permanently afterwards. Best of luck!
Chris...
Epicsurf
Post by Epicsurf »
I just happen to have a huge box of wine corks I'm going to give the court trick a try. I also dried up all the oils and now I can really tell where its coming from. Thanks again for all the help
turbozutek
Ah ha!! That looks awesome, almost as good as the upgraded cork top mount I built last year:
High Quality Engine Mount Repair.jpg (82.11 KiB) Viewed 1871 times
/Good luck with the diagnosis
Chris...
jblackburn
Looks like my "fix" failed on mine - it's leaking oil down on the exhaust again. Bah.
JD, I applied the silicone and let it set for an hour before driving like the instructions said. I might remove it and try again and let it set longer.
'98 S70 T5
turbozutek
How are you cleaning that before applying silicone? I'd think it would be really difficult to get it oil free enough for silicone to work, no?
Chris...
