Central Locking Relay Location?
Madhelpermonkey
- Year and Model: 850-1996
There wasno control module with the lock assembly just and actuator. I saw 2 relays in the wiring diagram for the locking system with remote what is a deadlock relay?
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Sorry for taking so long, could you point me to the diagram that you are using?
Thanks
Thanks
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Madhelpermonkey
The 1996 850 Diagram set in the repair database. Its page 6 of the PDF. My Haynes shows a deadlock relay on the point to point diangram. Also There is a diagram for 2 stage central locking for 4 door which is page 73 on the PDF
Madhelpermonkey
Oh dang is that a relay IN THE DRIVERS DOOR I see on the diagram??? hmmm I think a picture of the problem may be developing in my little pea brain....The component list in the volve wiring diagram identifies the second relay on the point to point diagram as "Driver Door 2 stage locking relay" ooooooo it makes me made when I miss things like that...I could just SPIT!
- regent
Chris,
That is probably what I was trying to call 'a Door CTRL Module' awhile ago (I guess I was a little bit 'too hasty', no?)
I am positive you will solve this puzzle before I do - you have the advantage of having access to both: the schematic and the car at the same time and location
Thanks
Thanks
2015 BMW 335i
2015 BMW 335i
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I don't know where you're seeing a relay in the door. Do you mean 2/105 ( relay 202) ? That's under the hood.Madhelpermonkey wrote:Oh dang is that a relay IN THE DRIVERS DOOR I see on the diagram??? hmmm I think a picture of the problem may be developing in my little pea brain....The component list in the volve wiring diagram identifies the second relay on the point to point diagram as "Driver Door 2 stage locking relay" ooooooo it makes me made when I miss things like that...I could just SPIT!
And I agree that if the "ALL OPEN" gets the driver's, then to me, that kinda points to the central locking unit.
I take a crack at swapping it with a known good. Go for the easy stuff first.
kiss4afrog
- Year and Model: 850 1995
- Been thanked: 2 times
After all this ..... What did you find ?? Did you fix it ??
You can never have too big a Turbo !
- 738 Views
Last post by banjoman
- 4390 Views
Last post by WA-Boater
- 3498 Views
Last post by polskamafia mjl
- 990 Views
Last post by Dalpatine
- 1237 Views
Last post by Window_Licker
