2000 S70 No Start, feel like I've tried everything...
This topic is in the MVS Volvo Repair Database » 2000 S70 No Start
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
Any luck with getting your car started?
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
A bad engine coolant temperature sensor will give you the no start condition you are complaining of. If you replace it, be sure to replace the thermostat as well.
Let us know how you make out.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
aamose
Year and Model: V70 GLT Turbo 1998
Post by aamose »
Howdy, Guys! Great conversation. My problem is less troublesome. My V70 '98 GLT Turbo that I got two years ago is good, except it does not start when the weather is cold, under 70 degrees. I found out by watching mechanics that erasing the codes allows it to start right away, no matter the weather. So I bought a little code reader/eraser, and it's been wonderful. I've tried several changes in parts, throwing money at it, but have not found the solution. Next I'm replacing the starter relay, since it began giving me the code for high circuit input for it. Hopefully that may take care of the problem. If not, it's only 29.00 bucks. Any suggestions? I'm definitely checking that ground cable described above. Thank you, Guys!
