Wind chill is all about the rate of heat loss.
Wind chill is the increased rate of heat loss due to air circulation. If there is no heat source, such as a battery not under a load, there is no rate of heat loss to increase.
At the most, Wind Chill will make it harder to warm up a cold battery so that you get the car started. This only comes into play if air is blowing around the battery. If the battery is in a protective case, low or no air circulation, no play.
Anybody that has blown on something hot to cool it off faster has made use of Wind Chill.
Blowing on something that is already at ambient temperature will not lower the temperature below ambient.
Will a battery with larger capacity cause damage?
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
When DiCE is plugged VIDA displays battery with key turned POS-II. It also reads 14.xx for something during diagnostic -- engine running. Is there an ECM- for parameters associated with battery, charging, generator etc?jimmy57 wrote: 01 Feb 2019, 08:17 Just give it a bit more time and your car will watch battery overnight and send you a text that your car's battery is weakening at accelerated rate.........(there probably is a car that already does this, I'm not sure)
- 3168 Views
Last post by 93Regina
- 676 Views
Last post by tryingbe
- 3292 Views
Last post by Rattnalle
- 2034 Views
Last post by motormikeyman
- 1358 Views
Last post by V50M66
