04 volvo c70 larger calipers
jenkinskg
Year and Model: 04 c70 hpt 98 s70 xc
Has thanked: 1 time
Post by jenkinskg »
After buying pads last time I realized the c70 with 17" wheels had 2 different caliper disc sizes.
My car has 17" wheels but has the smaller brakes.
I think some of the v70 awd wagons had same brakes but larger, maybe R model.
Who knows what I should order to get mine to the bigger brakes?
I assume change calipers, discs and pads, which v70 r shares same spindles?
2004 c70 2.3HPT, s60 2.5T
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Your keyword here is "302mm brakes". That's what you want. C70s got both 280mm and 302mm. I've never read of a rhyme-or-reason for the C70s getting two sizes. R's got the big brakes.
viewtopic.php?t=46093
302mm brake upgrade on 850
Big brakes on small wheels
more
https://www.matthewsvolvosite.com/searc ... ge?q=302mm
Also -> Amazon link
jenkinskg
Has thanked: 1 time
Post by jenkinskg »
Awsome, thanks
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Caliper size is the same, brake pads are also the same between 280mm and 302mm.
Caliper bracket is different, so are the size of the brake rotor, and length of the brake hoses.
85 GLH, 367 whp
00 Insight, 72 mpg
