I am sorry, I misphrased my sentence.
It should read:
- If you jump the 15-87 and car runs, fuel relay is bad.
- If you jump the 15-87 and car does not run, fuel pump (or wiring to fuel pump) is bad.
Sorry for the confusion!
1997 V70 XC Hard Cold Start
T-HADLEY
- Year and Model: 1997 V70 XC
cn90 wrote:I am sorry, I misphrased my sentence.
It should read:
Ok thanks, that makes more sence.
I will up date as the weather gets colder....
Thanks' again T.
- Been thanked: 504 times
Re Fuel Pump RELAY, you have 2 options:
1. New relay from dealer is about $50 or so.
2. Repair the relay using cheap capacitors ($2-3 from Radio Shack).
Search for the DIY by "Ozark Lee".
T-HADLEY
I did read that very cool stuff, I will be doing the radio shack upgrade on a few relayscn90 wrote:Re Fuel Pump RELAY, you have 2 options:
chungjodad
- Year and Model: 1999 V70 XC
It sounds like having the key in the On position for a couple of minutes for the code reader/eraser may have done something to enable starting. I'll try that.aamose wrote: 23 Oct 2012, 13:10 My V70 '98 won't start when there's cold weather, starts perfectly most of the year. Coolant temp. sensor and MAF did not make a difference when I changed them. I am next changing the starter relay. The way I found to make it start in the meantime was to get a small code reader/eraser and use it when it does not start. After reading and erasing codes, it starts right away, no matter the cold weather. I'll keep you posted about the starter relay. I'll change it this week.
My 1999 XC's symptoms are as described by others. When it does eventually start, there's an audible buzzing (fuel relay?) until the engine warms up a bit.
- 1449 Views
Last post by renegade343
- 25 Replies
- 4318 Views
Last post by 800artfreed
- 26 Replies
- 7207 Views
Last post by shegarty
- 1137 Views
Last post by oragex
- 848 Views
Last post by misha
