I am having problems understanding this. So, you lower the car but still have the jack supporting the control arm (at right height) and then bolt it down?rspi wrote:One of the most important steps in the entire process is loading the arm to the ride height before you torque the frame bolts. If you fail to do that you will destroy the frame bushings and they will wear out very fast.
96 Volvo wagon control arm replacement
Volvo S70, V70, XC70, 850 Control Arm Replacement
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- Year and Model: Many Volvos
- Been thanked: 76 times
I typically do it the other way. With the car on the jack stands I use a floor jack to jack the arm up to about final ride height (you get to a point where the car actually wants to come off the jack stands due to the sway bar) and the torque the two large bolts through the bushings down.mika wrote:I am having problems understanding this. So, you lower the car but still have the jack supporting the control arm (at right height) and then bolt it down?rspi wrote:One of the most important steps in the entire process is loading the arm to the ride height before you torque the frame bolts. If you fail to do that you will destroy the frame bushings and they will wear out very fast.
- 13339 Views
Last post by MarcM
- 2973 Views
Last post by 800artfreed
- 25 Replies
- 5220 Views
- 1151 Views
Last post by s_watts
- 4166 Views
Last post by Tonyx
