Yes it can look up the Bluedriver unit by Lemuir see Here for more details, engine codes only but the unit works well with the Crapple products, when it came out it cost $29:99 which was a real bargain, these days it will set you back around $99:95 - Mikemtd240 wrote:Sucks that iPhone can't do any of this..
Real Time Engine Monitoring with Smartphone - Questions
Smartphone Apps & Volvos
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
esl97850T5,
Thanks for the reply and info.
I might look into doing that IF I cannot find a more interchangeable option. Would like to purchase a Diag Tool that can communicate with a vast selection of vehicles. Kind of like a Tech 2, but more flexible to be used with at least Ford, Jag, BMW, Mopar, and VW and to cover upto but not limited 2013 for those brands.
I wouldnt be opposed to spend a few hefty bucks as long as I know it will do the job.
ugh smh 850 Turbo fridge
precopster
- Year and Model: Lots
- Been thanked: 128 times
Take a look at the Autel MaxiDas DS708 garage scanner. VERY versatile and robust and if you shop around on AliExpress it can be had for around $1,000.
Otherwise for far less Autel's MD 801 scanner has enough memory size to store most brands of vehicle files without having to re-flash its memory.
Which one is better, the full size ELM327 or the mini one? the full size one is more expensive. does that imply that its better or?
I don't understand vests... is it winter on your torso and summer on your arms??
- Mr. Lockwood
- Mr. Lockwood
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
NSFWaldo,
1. Provide us with a link to the full size and mini ELM327 devices you're referring to. That'll help us give some meaningful feedback.
2. Will you be using the ELM327 with your 2000 V70? What are you hoping/expecting that the ELM327 can do on the 2000 V70? Will you be using the ELM327 for other vehicles?
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
I would use it on my 2000 v70 along with other vehicles. but i know you can set up different profiles on it too. I was searching more and I guess the more expensive ones i saw were just ios compatible as well.
- Mr. Lockwood
- Mr. Lockwood
- 1647 Views
Last post by XC70Rider
- 3687 Views
Last post by ggleavitt
- 2787 Views
Last post by KTTYR
- 2291 Views
Last post by hanacaptain
- 25 Replies
- 7071 Views
Last post by Blacklab467
