1999 V70R possible burnt valve?
1999 V70R Possible Burnt Valve?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Yes I do believe it will fit fine, if your car is a T5.
- Has thanked: 311 times
- Been thanked: 817 times
Yes, for sure a 2000R engine will work in a 1999R.
You can make a newer engine work too with minimal tweaks, that is what a lot of people are doing now, but I do not know the details. Check out Volvospeed.com if you want to look into that.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
look at car-part.comHWG09 wrote:Any suggestions on where to source new engines? I found a couple places on google. would a 2000 V70R engine fit in the 1999?
you could get a junk yard motor and have that head machined. as long as the valves are good you can do the replacement yourself. so you dont really need a new motor.
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
- rspi
Contact rspi..
I would check compression on the rest of the motor. If the numbers are good, I'd replace the head. Also have that injector checked.
I also like replacing the head if the bottom checks out - because you can replace all of the valve stem seals (and the rest of the top end seals) when you do it. If you put a head in there with 15 year old seals, you are rolling the dice ...
- rspi
Contact rspi..
If you find a good motor cheap, go that route. I found a good motor for under $200 once. You can't beat that.
Also, check with your local head shop. Some are real expensive with rebuilding the head. You may find it cheaper buying a refurbished head. Keep your finger crossed if you get a new head, I spoke with a guy recently that received a BAD new head.
Apparently Omaha not the best place to get an engine rebuilt, much less a Volvo. One guy quoted me $3000 to rebuild the head and everything. No thanks.
Still looking at different options but have to speak to this dealership who gave me the bad oil change. I'd at least like them to take it in but I'm worried they'll come up with some reason why it wasn't their fault only after they've pulled the head and charged me $500. Supposedly they have a good reputation but I don't really trust dealers anyways.
they always will shift the blame. but honestly, how do you figure a bad oil change caused this? you said they only put 5 quarts in, thats all it takes. 5.1 if you wanna be technical. in order to fix this as cheaply as possible, you need to remove the g=head yourself and bring that to a machine shop for work. they will replace the guide seals and bad valves. its up to you to do the cam seals and valve cover seal. there is no way you are getting through this spending less than $600. i wouldnt just throw in a "good" used motor either. cause if you think about it, if the "new" motor runs it doesnt mean something wont go wrong. yours was running just fine until then as well. so you are rolling the dice on a used motor. if you find a used motor just pull the head and check it out, cause thats all you need.
- 14 Replies
- 2987 Views
Last post by bmdubya1198
- 643 Views
Last post by E Showell
- 558 Views
Last post by dosbricks
- 1289 Views
Last post by rspi
- 66 Replies
- 8512 Views
Last post by PeteB
