98 Volvo S70 GLT A/C Compressor fault. Replaced AC switch 30767231, 8628563 Topic is solved
1-2 40 kOhm
2-3 40 MOhm
Measured at sensor on my 99
2-3 40 MOhm
I got also one sensor from 99 XC. And i tested them, pin 2 (the signal out was 0,9-1,5V with working pump), it came out it wasnt the bad sensor. It was engine ecu. Luckily i had another ecu, and it is working. Fol-FCR is showing correct values now. But climate pump still switches off after ~5min, so i guess its the clutch that has too large gap and gets overheated. Will sort this out and keep you guys informed.
- 2478 Views
Last post by TripleThreat719
- 570 Views
Last post by vtl
- 13 Replies
- 2457 Views
Last post by ferocity02
- 523 Views
Last post by XavierEduardo99
- 1414 Views
Last post by oragex
