1998 S70 T5 Towing another car
This topic is in the MVS Volvo Repair Database » Towing a Miata with an S70
DrJammer
Year and Model: 2000 V70XC - 195k
Has thanked: 1 time
Post by DrJammer »
just typing in general info into uShip (disclaimer - I've never used), just a quick google search looks like it could be done for ~700 bucks? look into anything, I recently moved residences and hired a small local group of movers that moved mostly old restored cars in a modified circus truck. I bet they would would be cheaper than an online vendor.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
QuirkySwede
Year and Model: 1998 S70 GLT
Been thanked: 12 times
Post by QuirkySwede »
abscate wrote:Most manuals are splash lubricated by sump in the gearbox. You should check with Miata experts on this to see if this is the case. If it is, tow away.
False. You have to look at how it is "splash lubed" as they are seldom as simple as they appear. Most transmissions' gears are constant mesh, it's just a matter of which are engaged to the shaft. As such, the gears require lube between the gear and the shaft they spin on (when that gear is NOT selected, hence in Neutral ALL gear pairs have at least one spinning on a shaft requiring lube on the INSIDE), the shaft often having a oil passage hole for the journal and the shaft being hollow to the end by the bearing. The bearings can be fed by slung oil caught in a drain tray or such which drains into that hollow end of the shaft which in turn lubes the gear spinning on the shaft. Starve it for lube and it wears the bush. Worn bush allows the gear to wobble. Wobbling gears' teeth have accelerated wear. Accelerated wear ...
So putting the car on the dolly and expecting the transmission driven by the rear wheels to remain lubed is like tilting your house 15 degrees and expecting your roof's gutters to still drain properly.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Those tow bar contraptions are dangerous (especially the HF $70 model)and I would never do a long haul tow with one of them. I was towing a buick park avenue with a ford explorer (I know, I used to buy/repair/sell Domestic and Japanese models before I went Full Euro) and everybody knows you cant go Full Euro and ever come back. Anyway the Buick fishtailed when the tow bars bent and smacked into the rear of the explorer. Two cars with body damage on maybe a ten mile tow.Good thing together I only paid $1500 for them both. Anyway sell the Miata to a female college student (women love Miatas for some strange reason, they must remind them of the Barbie convertible) and never tow anything more than a few miles with your S70 as they already have Valve body solenoid problems in the transmissions as well as usually neglected trans fluid. Good Luck.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Removing the tailshaft of the Miata disconnects any impact of road movement to the manual transmission. This is cheap insurance.
However the S70 transmission WILL suffer.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I'll just leave this here. No idea where I found this. That trailer packed with stuff likely weights more than a Miata, right?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
I'm guessing that trailer weighs 1500 lbs, empty. And I thought I towed too much!
I'm surprised the U-Haul shop rented a two-axle trailer to this person.
Also -> Amazon link
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Post by mecheng »
For whatever it is worth, my friend is into boats and he tells me the boat guys love Volvos because they can tow heavy loads, and their rear suspension is heavy duty
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 1609 times
Been thanked: 4065 times
I towed my t5 with the v70 NA 200 miles taking it nice and 55 easy.
More crazy towing…..
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Video of caravan towing.
No one I know.
