Oil change intervals?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Re: Oil change intervals?
Post by oragex »
The only oil that will cause wear in an engine specified for 5W30 oil, would be using a 5W20. A 0W40 should be fine in a 5W30 spec engine. In fact, I think the W40 factor means it will protect the engine more in very hot weather. The 0W will work great for very low temperatures start, but a 5W synthetic oil is already more than enough in very cold weather starts. Even a 5W non synthetic still pours well at 0F. It think only in Siberia or Alaska a 0W will be really needed.
benrk
Year and Model: '01 V70 XC
Post by benrk »
oragex, check your manual again, 5W30 is not exclusively recommended, in fact it's insufficient in temps above 86F, mountain driving or towing & they want you to use 10W30 or 5W40 instead, for towing a boat or camper through the mojave in summer I'd probably pour 15W40 or 10W50 in.
And let me assure you by own experience, 5W40 is not excessive in cold weather, it much rather is probably the thickest stuff working at all, as I was out of 0W40 after engine work last summer & poured in 10W40 semi-synthetic that I stock for my classics, as winter came early & harsh, one fine -15F morning a low oil pressure message reminded me that I was still running summer-tar in the sump.
Greetz, Ben
‘14 BMW i3
‘09 BMW 535XiT
oragex
Post by oragex »
benrk wrote:oragex, check your manual again, 5W30 is not exclusively recommended, in fact it's insufficient in temps above 86F, mountain driving or towing & they want you to use 10W30 or 5W40 instead, for towing a boat or camper through the mojave in summer I'd probably pour 15W40 or 10W50 in.
Greetz, Ben
Agree, the 5W30 has a more mid range usage. A 5W40 ( or 0W40) would be a good oil to run from cold weather to very hot summer days.
Has thanked: 1497 times
Been thanked: 3809 times
Thx for keeping this civil everyone.
Generally, oil change/brand/interval threads have to be safely redirected to less controversial topics like "will Palestinian sovereignty be respected by Israel on religious or political grounds and why?"
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
benrk wrote:Annually, in the fall, somewhere near 10tkm, usually German brand filter like Mann, Mahle or Bosch, 0W40 full synthetic oil typically Liqui Moly, but also Mobil 1 (European car formula) or Castrol Edge (European made) if out of LM.
For the oil I'm mainly looking for VW 505.00 approval as it was an update to their oil specs after the 1.8T motors developed oil sludge issues with the earlier formular, sounds familiar? ;-)
How is liqui moly? Just got an 04 xc70 and was thinking of getting liqui moly 0w30 and mann filter.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
shiloh51933
abscate wrote:Thx for keeping this civil everyone.
Nice!!
benrk
Post by benrk »
If you research LM you'll find that they make excellent oils, but in the end it is just that, a good oil that you can just as much get from other quality brands, apart from being German & LM being the oil of choice for many gearheads in Germany, I also like that they take some social responsibility & pay good wages & are still producing in Germany, though the high end Castrol oils with approval for German makes are also made in (Western-)Europe, I just prefer a midsize company under local ownership to transnational corporations like ExxonMobil or BP (Castrol).
As mentioned earlier, 5W30 & 0W30 I would only use as a winter oil, NY state has a fair amount of hills & throughout the summer quite frequently temperatures above 86F, 5W40 would be the OE recommended viscosity for your use, 0W40 would be a treat for the wintertime, but given the rather mild winter temperatures near the coast probably not necessary.
Greetz, Ben
‘14 BMW i3
‘09 BMW 535XiT
shiloh51933
I'm jumping into this topic so I don't have to start a new thread, I'm looking into using European made synthetic oils for our new xc70('04). We have a '96850glt which gets Mobil1 5w30 extended and I recently started a drain/fill process using FEBI ATF #29934, did 2 drain/fills so far. I did the drain/fill process about 25-30,000 miles ago w/Mobil 1 ATF. Anyway, I'm thinking about using Liqui Moly 0w30 engine oil and considering using Aisin or Mobil 3309 ATF. Here's the deal though, she'll be driven for extended periods of time 3-5days a week. I figure up to 4 hours straight driving local/city style driving, a little bit of Hwy. I do not beat up on my vehicles and neither does the wife Since the xc70 is going to see much heat should I go w/0w30 or 5w30?
shiloh51933
As mentioned earlier, 5W30 & 0W30 I would only use as a winter oil, NY state has a fair amount of hills & throughout the summer quite frequently temperatures above 86F, 5W40 would be the OE recommended viscosity for your use, 0W40 would be a treat for the wintertime, but given the rather mild winter temperatures near coast probably not necessary.
Greetz, Ben
Appreciate feedback, I'm going w/Liqui Moly 5w40-Mann filter, Aisin atf or Mobil3309, just gonna buy an oil change kit from FCP Groton. Thanks again.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
shiloh51933 wrote:Since the xc70 is going to see much heat should I go w/0w30 or 5w30?
Yes, more heat => use 5W-30
At higher temperatures 5w would behave better than 0w
To the main thread: On my n/a 02S60 I use Castrol 10W-30 all year round; it is driven in hot climate zones all the time. Change oil + Mann or Mahle filter every 4kmi (add about a pint or two in between changes.)
Thanks
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
