1998 S70 Broken dipstick
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
My factory dipstick lasted 14y/140K. So not bad at all.
Chances are I don't keep the car that long (280K) to need another dipstick.
DragosGD
Year and Model: S70 T5 - 1998
Has thanked: 9 times
Been thanked: 6 times
Post by DragosGD »
Well, the original one maybe... but the new ones are trash! 30K Tops! Why do you think I have to replace my 1271920 ?? Beside that... the round wire style holds strong in the tube when you pull it out, which made the flat blade style the winer!!! Like Dutchtouch1 sad before, "Good luck"!
Post by cn90 »
The dipstick is made by many many people, Volvo, the aftermarket etc.
The Volvo OEM disptick lasts > 10 years.
You may have bought an aftermarket dipstick.
DragosGD
Post by DragosGD »
Bad news: genuine 1271920 dipstick from TASCA with VOLVO label on it - gone in less than 30K miles.
I'm not going over this again. Good luck with your choice!!
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
You never used it as a prybar, no? :lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If you think the new OEM is bad you should see the Scantech dipsticks. They probably won't last 5K miles. :lol:
Post by cn90 »
I think the solution should be a "better" O-ring.
The Volvo O-ring tends to be a tiny bit tight. In the process of pulling the dipstick out with a tight O-ring the round plastic handle may crack.
Given that many of these cars are over 150K-200K miles, I wonder if we need the black O-ring at all.
If the O-ring is removed (store it for later):
- You won't have cracked dipstick because it is easy to pull out.
- Your PCV system will breathe better!
precopster
It won't be much of a PVC "system" if it leaks fumes into the air we breathe!! :lol:
The Scantech one I bought has almost no grip from the o ring seals so likely that one is leaking all the time.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
My daughter upgraded to the new dipstick and has a hard time pulling it out to check the level. Very tight.
JasonBee
Year and Model: 1998 S70 GLT
Post by JasonBee »
I am so glad I found this page!
