96 850T Delta Link and Trailing Arm Bushing Replacement Saga
- Has thanked: 1614 times
- Been thanked: 4078 times
...looks you are winning....
You have inspired me to do this one myself !
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I wish you hadn't said "Scan Tech" -- universally condemned aftermarket parts on here for being cheap Chinese junk. No experience with their delta links (thankfully) but plenty of unflattering remarks on here for their other parts. Hope you have good luck with yours.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
E Showell wrote:I wish you hadn't said "Scan Tech" -- universally condemned aftermarket parts on here for being cheap Chinese junk. No experience with their delta links (thankfully) but plenty of unflattering remarks on here for their other parts. Hope you have good luck with yours.
Thanks for the encouragement!
'00 S70, '04 S60 and the never ending quest for Stage Zero
- Has thanked: 2866 times
- Been thanked: 1332 times
- RussB
In my defense, the delta links were bought in 2010 and the bushing was bought in 2006! The Pro Parts left-side bushing I just got today from FCP was made in South Korea if that's any better
Lee gave his Scan Tech Delta Links 100k thumbs up - this is documented in the PARTS Forum
https://www.matthewsvolvosite.com/forums ... 30#p335730
I have tons of parts just sitting.RussB wrote:![]()
- E Showell
I stand corrected. If Lee gave them a thumbs up, they'll probably be just fine. Stay away from the door checks, though.
'95 855 auto (sold)
'95 855 auto (sold)
- RussB
The battle rages on...
I tackled the driver's side today after work. All in all, the delta link went well. I think it would've came out with just the puller, but I burned it just to make it smoother, plus I had the torch and fire extinguisher all ready anyways...out and in took about an hour.
The problems blindsided me. I needed to remove the IPD sway bar to access the bolt that attaches the busted bushing to the trailing arm. The "easy side" would only let go after soaking in Kroil and a serious beat down with a 3# hammer. New hardware had to be ordered from IPD and I'll have to take the rear sway bar to work and drill out the frozen bottom bolt in the pic, which had to be cut off with the Sawzall
Then there was the broken bushing. What a battle. The Sawzall was once again employed. The bolt that attaches it was frozen in the metal sleeve that's molded into the bushing. It took all my impact wrench had to drive it out...
This is one tough back yard job
- 2532 Views
Last post by Kazthebassman
- 18 Replies
- 3304 Views
- 15 Replies
- 5892 Views
Last post by Keithnysm
- 2064 Views
Last post by Krons
- 16 Replies
- 4813 Views
Last post by kahl
