Heater Core Firewall Junction/Coupler bypass - DIY write-up
Heater Core Hoses Fix
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
Retired:
2015 Volvo S60, T5, 85K
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Ya, it works 100% of the time. You're just removing the brittle plastic coupler and replacing it with heater hose.
- theWIFES_S70
Sounds good to me! Thanks polskamafia mjl!
Retired:
Worked for me, did this mod last winter. FWIW I replaced the last "old" section of hose in the coolant system on my 850, the upper reservoir return, with Volvo OEM this past weekend. Pricey little piece of pre-formed hose, but it needed to be replaced.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Probably 10k on my bypass, and it's working great.theWIFES_S70 wrote:Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
Everything else on the car has fallen apart.
- Been thanked: 504 times
Look at my post DIY right before your post above.theWIFES_S70 wrote:Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
It works perfectly and the cost was peanuts.
- theWIFES_S70
Oh man, I forgot to order the Volvo OEM o-rings! (3545586) Thanks for that heads up!cn90 wrote:Look at my post DIY right before your post above.theWIFES_S70 wrote:Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
Retired:
I should of mentioned I sourced the heater hose locally. Long story short, I bypassed the heater core when I replaced my head gasket last fall because the firewall junction leaked when I plugged in the new heater core hoses. I took the old heater core fitting to local auto parts stores until I found a decent heater hose that fit snuggley. I think I paid about $5 for three feet of hose. I also didn't drain my coolant when I did the hack. I took a couple of wine bottle corks and whittled them into plugs that fit the heater core hose. Then I removed one end of the bypass hose, plugged the bypass hose, held my thumb over the fitting from the engine and then quickley shoved the fitting into the new hose sticking out though the fire wall. I lost a little coolant, maybe 4-6 oz., but it was a lot easier than draining the system.
- theWIFES_S70
Man, what a life we've chosen for ourselves, huh?j-dawg wrote: Everything else on the car has fallen apart.
Retired:
- theWIFES_S70
Thanks bugs11, I ordered a roll of 6 feet of Gates hose from Amazon. I think it was 9 bucks. It certainly looks and feels like strong hose. Of course I'll throw up my pictures after I get it done. I have so many corks lying around... I would do this, except I am going to replace ALL my hoses, they're all bulbous! (Like I mentioned in another post, I really do not want to drain this system again...) I am going to keep that wine cork trick in mind though. I like it!bugs11 wrote:I should of mentioned I sourced the heater hose locally. Long story short, I bypassed the heater core when I replaced my head gasket last fall because the firewall junction leaked when I plugged in the new heater core hoses. I took the old heater core fitting to local auto parts stores until I found a decent heater hose that fit snuggley. I think I paid about $5 for three feet of hose. I also didn't drain my coolant when I did the hack. I took a couple of wine bottle corks and whittled them into plugs that fit the heater core hose. Then I removed one end of the bypass hose, plugged the bypass hose, held my thumb over the fitting from the engine and then quickley shoved the fitting into the new hose sticking out though the fire wall. I lost a little coolant, maybe 4-6 oz., but it was a lot easier than draining the system.
Retired:
- 3305 Views
Last post by blandis
- 19 Replies
- 3678 Views
Last post by xHeart
- 785 Views
Last post by 99TurboBrick
- 32 Replies
- 18087 Views
Last post by sleddriver
- 1647 Views
Last post by vvvolvo
