Sure, there are ways to test the head.
So where are you thinking the problem is in the head, that matches the symptoms here? And would be picked up by a leakdown. I'm just not seeing it. You will recall OP already has good compression numbers.
94 850 turbo Cyl 5 Misfire
- Has thanked: 311 times
- Been thanked: 817 times
IG-88A
- Year and Model: '94 854T-'95 855GLT
For posterity's sake, or redundancy's, here are warm compression numbers with WOT. 130, 130, 136, 132, 127.
I had the pleasure of speaking to a retired gentleman tonight who works on cars on the side now. He spent thirty years as a tech at a local luxury dealership servicing Benz, Jaguar, Rover, Porsche, etc, no Volvo though. He is a wealth of knowledge, and is 99% convinced that this is nothing more than a vacuum leak leaning the 5 cylinder. He's agreed to help me locate the issue and take it on as a team early next week. I'm looking forward to working with this fella.
As for the European shop that said I needed a new head, I think I'm done with them. Upon deciding to do a proper compression test tonight, I became increasingly suspicious. I have one spark plug cover bolt that's slightly stripped. And lo and behold, its in the exact same hole that I put it in Saturday. One in six chance, I guess. Hmm.
IG-88A
An update on an old topic. Sorry for reviving it. I got busy with stuff and forgot to report. It was a torn intake manifold gasket. Just like Volvofan94's. Same place and everything. Problem solved. Thanks for the help everyone. Now to find that 143 problem.
Thanks for posting. Just seemed no way this was a head problem, good to see that confirmed.
- 1718 Views
Last post by petermetzger
- 1737 Views
Last post by Livens
- 1842 Views
Last post by FLXC90
- 1643 Views
Last post by AD_NAPCO
- 1705 Views
Last post by Kazthebassman
