1999 S70 NA PCV system fix caused misfire
kyalami321
Year and Model: 1999 S70
Re: 1999 S70 NA PCV system fix caused misfire
Post by kyalami321 »
Ok, finally fixed and it was the stupidest - yet cheapest - thing ever ... the coil wires were hooked to the wrong cylinders. Thank you all for your help regardless.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Awesome that you posted up the solution, thank you, it really helps. Trust me, you will by far not be the only one of us to make that miscue!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1505 times
Been thanked: 3818 times
Way to go. Label them with some white tape so the next time this doesn't happen.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
kyalami321 wrote:Ok, finally fixed and it was the stupidest - yet cheapest - thing ever ... the coil wires were hooked to the wrong cylinders. Thank you all for your help regardless.
You allready had been pointed into that direction:
Sommerfeldt wrote:...Anyway - just to rule out the absolutely most basic thing that could cause your troubles... You're sure that you put coils and plug wires back in the right order...?
- S
8)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kyalami321
- S
8)
Yup, I was. I didn't even consider that "order" meant specific wires tied to specific cylinders, but now I won't forget. Timing belt or suspension work will be my next projects. Thanks!
Remember an ME7 doesn't have cap rotor and wires - just plugs that attach to coil-on-plugs
I bet someone has tinkered with the wiring looms as on my 1999 you can't get the plugs into the wrong coils without really straining them.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
abscate wrote:Remember an ME7 doesn't have cap rotor and wires - just plugs that attach to coil-on-plugs
I kinda see what you mean, abscate, but if I remember correctly, it's possible to mess it up if you route the cables wrong between the coils. 3 & 4, for example.
Anyway, it's good that the battery mishap didn't screw anything up, kyalami. :) And whenever the solution is the cheapest one, then that counts as a good day. :D
- S
[Sold] '97 S70 T5
