Bmw driver was pretty surprised when i pass it at 200km/h in light curve on freeway.
'97 850 GLT metal in oil?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
He....you did that with a T5.I did that few times with my non turbo.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
230,000 isn't "entirely a lot" of miles if it's been taken care of.
I can never quite tell if these cars are particularly durable or if they have owners who tend to take good care of them. Probably some combination of the two.
- Has thanked: 316 times
- Been thanked: 531 times
I'm sure it's a combination. I've seen some pretty ratty looking ones with upwards of 250k-300k on them, but I've also seen some really nice ones with those kind of miles.j-dawg wrote:230,000 isn't "entirely a lot" of miles if it's been taken care of.
If you take care of any car, you'd be surprised how long it can last.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
As for a NA car being as "peppy" as a TURBO 850, I have 5 words for you guys...
1. Get
2. Your
3. Turbo
4. System
5. Fixed.
I have a little over 291,000 miles on my '95 T-5R and pulled my turbo to install a 16T with less miles. My 20 year old turbo with over 291,000 miles on it is as tight as a drum and is not leaking a drop. It is actually tighter than the 16T that I had installed with only 135,000 miles on it.
Sad fact is that I have found SEVERAL of these turbo cars with all kinds of vacuum lines hooked up WRONG. Causing the car to boost around 1 or 2 psi.
Real sad story is that a guy had a very well maintained '97 850 T5 with all kinds of new parts on it. He suddenly experienced very poor performance and somehow came to the conclusion that the engine was bad. My friend got a hold to it and rapped it. The car showed up in the junk yard today and my friend pulled the radiator. When he did, he discovered a tennis ball size hole in the intercooler. Car trashed and scrapped for a $50 intercooler problem. SMH
1. Get
2. Your
3. Turbo
4. System
5. Fixed.
That's sad. I need to go save a T5.rspi wrote:As for a NA car being as "peppy" as a TURBO 850, I have 5 words for you guys...
1. Get
2. Your
3. Turbo
4. System
5. Fixed.
- Been thanked: 4068 times
I've got to find a way to limit boost on my T5 for Abby in college ; that's not going to be easy to drive in winter
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
abscate wrote:I've got to find a way to limit boost on my T5 for Abby in college ; that's not going to be easy to drive in winter
Manual boost control set to wherever you want it. Adjust the wastegate to have the boost come on "later"
Put 4 good 15" snow tires on it as well and save the Pegs...young girls don't always avoid the pot holes
'00 S70, '04 S60 and the never ending quest for Stage Zero
+1 on the boost controller. And the wheels, too, haha.RussB wrote:abscate wrote:I've got to find a way to limit boost on my T5 for Abby in college ; that's not going to be easy to drive in winter
- Has thanked: 311 times
- Been thanked: 817 times
In response to one of your earlier questions: Drop an HPT engine and turbo into the 97 GLT, also swap over a 97 HPT ECU, and you are driving a T5.
Thanks! It says I drive a '99 T5 because I had that there for questions. It's my cousin's car, I don't have a Volvo... yet.erikv11 wrote:In response to one of your earlier questions: Drop an HPT engine and turbo into the 97 GLT, also swap over a 97 HPT ECU, and you are driving a T5.
- 2925 Views
- 1247 Views
- 11 Replies
- 1571 Views
Last post by obayha
- 2214 Views
Last post by howierodgers
- 553 Views
Last post by dux02v70
