1998 V70XC Door Vinyl Removal and Refit Part 2
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
C1ph3r wrote: 29 Aug 2024, 07:26 Oh my foam is trashed so I’m using what came from redline. And thanks for the tips. I wouldn’t have thought about doing the inside of the cups then the walls as 2 steps to prevent tension. I’m probably going to use my steamer and steam the leather a little to get the shipping wrinkles out.
This is my first time also and I’m doing a rear door first. So I’ll learn from back to front. Hopefully by time I get to the drivers door I’ll have it down
Steamer would probably be great. And just to clarify, by bottom of the cups/sunken part, I was talking as if the door panel was laying down flat on the workbench. I started with the rear passenger door and worked my way up to the drivers door. Drivers door has a slightly extra complexity because the speaker grills retain the leather, and are secured with melted tabs. I dremeled mine off very carefully, and then melted zip ties on the backside of the tabs to secure them back.
I really should have done a writeup in a thread after the job, but I lost all my pictures that would have broken up the wall of text.
Good luck with this project.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
