1999 V70 T5 - Broken Hatch wires lead to no-crank condition, Manual trans 9168056
How To Troubleshoot Volvos
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Failing transponder in the chipped key or bad ring around ignition lock?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
See up thread. Wiring fault in tailgate led to fuse fault on central locking system which inhibits starter on ME7 cars.
- misha
Somehow i missed whole 2nd page.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
precopster
- Year and Model: Lots
- Been thanked: 128 times
I missed the entire thread!!
I stay away from the forum for 1.5 days and I miss an epic adventure
I wonder if P2s have a starter bypass like that. Makes me want to fix the 2001 T5 (blown HG at the moment) sell it and keep driving my V70 P80 just to keep things simple.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Glad you found the problem. When you take your next crack
at the failing wire in the hinge harness, you might try replacing
it with something more flexible. I've upgraded a number of sections
of "moving" wire with arctic grade jacketed wire with a high strand count
of copper. Here's are links to a place that sells multiple colors and gauges:
http://store.polarwire.com
http://store.polarwire.com/browse.cfm/s ... 2,714.html
You can also strip out the conductors from low temp SJOOW extension cords.
I usually confirm it's the better quality stuff with the low temp rating of -40.
Good soldering and shrink tube on either end of your spliced in replacement
and you'll never have to deal with the notorious broken tailgate cabling again.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Thank you all for this information. It's so good to know that this can befall a manual transmission P80... Now. I wonder if I need to do this!
Retired:
2015 Volvo S60, T5, 85K
After repairing the hinge wiring, all well
Clutch seems to require longer stroke to actuate cranking, probably as result of my cleaning.
I'm calling this one totally on rear hatch wiring, by the way, I think the clutch switch was a red herring.
Hatch wiring short......popped number 6 fuse....inhibits central locking....inhibits starting on ME7.
The clutch switch inputs go into the ECU directly, so I can't troubleshoot that further without some serious schematics
- Has thanked: 2857 times
- Been thanked: 1332 times
Fantastic troubleshooting skills, Mr. Moderator. Glad you found and corrected the problem so quickly.
Follow up on this. The clutch throw required definitely went up, and today.....cruise control went out.
Also, hit a bump on the pike and ABS light came on...I'll bet my rear right ABS sensor wire fix gave out.
Checking....
Checking....
- 386 Views
Last post by JimBee
- 1658 Views
Last post by mrbrian200
- 204 Views
Last post by Ethan5150
- 1272 Views
Last post by rspi
- 11 Replies
- 2697 Views
